Identify open parts of lines
All  1  2-5
9930.2 In reply to 9930.1
Script Naked Edges then zoom on them
script: /* Naked edges */ var gd = moi.geometryDatabase; gd.deselectAll();
var breps =gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i )
breps.item(i).getNakedEdges().setProperty( 'selected', true );
9930.3 In reply to 9930.1
Hi Axel, for surfaces the script Pilou shows above will show the "naked edges" of the object, those are edges that only belong to one surface and are not joined between 2 surfaces like a solid needs to have.
For working on curves only and not solids, there is a script here that will mark the end point of open curves with a point object so you can see where to investigate for gaps or cross-overs:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2888.11
9930.4 In reply to 9930.3
Hello Michael, Hello Pilou,
thanks for the answers. Mainly I would need that for open curves, not surfaces, so I installed the script you provided. That's really interesting how it works now. I can join open curves and even there is a gap it joins and I would never identify it as an open curve, cause it's joined. But this little tool shows the overlapping or the gap with the point.
Great!
Best regards,
Axel
9930.5 In reply to 9930.4
You have also this who select points of curves and
highlight a cluster of Points based on a set criteria. Like if a curve was!
Selected and the script turned on any points that where within 2mm from each other. (or anything you want)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9614.5
EDITED: 1 Sep 2020 by PILOU
Show messages: All  1  2-5
