Offset holes / bolean / AUTOMATION IDEAS....
 1-4  5-24  25-33
9929.25 In reply to 9929.18
Thanks for the feedback regards OpenSCAD.
From some of the additions I've seen posted here what I was thinking of is certainly doable, just takes a deeper understanding of MOI.
Frederick
I use MoI to design parts for 3D printing - Everything from fixtures to electronic enclosures to CNC machine components. Clearance is a big consideration as nobody likes having to drill or file parts to make them fit.
For bolt holes and heat-set brass inserts I use the method described by Barry above - That is, an object library of pre-defined "hole cutters".
For parts that fit together (example: a stepper motor boss fitting into a bracket hole) I normally enlarge the part (the motor) slightly by resizing it, perform the Boolean diff operation, then re-size the part back to its nominal dimensions. It would be cool to have a short cut key you could press just prior to a Boolean diff that would enlarge the resulting opening by a predefined clearance distance.
9929.27 In reply to 9929.26
Hi Ed, I am almost expert at revolving plug type fixings now :0)
I do like this mcad approach below, kinda what I explained before. ..
It's its from Ironcad, oops dont like its price...
it's like create part, save it in 'library' (or object layer¿), apply holes to selected surface / hole position(s)...
This is sort of tidy interface works but even a list of variables would be workable and cover basic hole types.
Well documented here:
http://www.ironcad.it/en/manuale/holes
Just ideas or doable?
Stefano
9929.28 In reply to 9929.27
Something like that should be possible.
See attached. These are the controls from a add-on for creating bolts, nuts, etc.
Frederick
EDITED: 26 Mar 2025 by FCWILT
9929.29 In reply to 9929.28
Hi Fredrick,
Yes. That is a good place to start with Max's script. Add a counterbore detail and a standardized sizing for clearance.
Wayne
UnOfficial MoI Discord server:
https://discord.gg/zNTasYd
And don't forget the Orient / Line - Line who has Uniform, Stretch, None deformation!
9929.31 In reply to 9929.30
Nice tool that orient but not had time to try it yet.
I think really prefer 'Michaels Revolution'...
Basically, from working out my 'approach' to 'spin' a counterbore
or countersunk hole to precise 2d dimensions as the starting point...
it all got a bit experimental. From just about 5 profiling shapes the
'spinning tools' was born and this 'design' was created.
On one of the profiles I could even create a rivet inside a cylinder....
!!! 'Sold' !!!
Stefano
PS. Does the custom ui work on trial version, I had a quick go yesterday but got stuck ?
EDITED: 3 Sep 2020 by LIGHTWAVE
9929.32 In reply to 9929.31
Hi stefano,
Yes, it does. You would want to get CustomUI.1.03.win.mac.zip , from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Some more detailed installation instructions at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9769.4
9929.33 In reply to 9929.32
Hi Michael, thanks for rapid reply, well spotted I downloaded wrong version...Stefano.
Show messages:  1-4  5-24  25-33
