Need help: Duble name of Solid
 1-16  17-31
9928.17
You guys are awesome!
Thanks to everyone - and especially Michael! - for help in work.
MOI3D is the most amazing tool I have ever worked with!
Now I can continue to work on my little W.I.P. :)))
9928.18 In reply to 9928.16
Yes, I speak Russian, I use a translator on this forum.
It's as good as a steam train! ;-)
EDITED: 30 Aug 2020 by WN
9928.19 In reply to 9928.18
I`m too :))
Рад встретить русскоговорящего коллегу и спасибо за советы!
9928.20 In reply to 9928.19
Я тоже рад такой встрече и всегда приятно когда совет оказывается полезен.
I am also happy to have such a meeting and it is always nice when the advice is useful.
Michael and the rest of the participants in this forum, I apologize for the deviation from the English language, sometimes it is easier to explain in your native language.
<< Is there some script (or a command like N that shows empty planes) to spot these problems?
script: /* Show edges no complet */ var gd = moi.geometryDatabase; gd.deselectAll(); var breps =gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
9928.22 In reply to 9928.21
Frenchy, hello!
Installed your script, opened file with corrupted geometry.
Allocated solid.
activated the script.
Alas, nothing happened.
Perhaps I misunderstood how this should work?
This is a script to show problem areas with defective geometry, right?
ps. The picture shows the problem area with the geometry from my file.
Size: 62.6 KB, Downloaded: 19 times, Dimensions: 712x518px
9928.23 In reply to 9928.22
It detects "Naked edges"...(enlighting wrong edges broken in "yellow")
If you have nothing when you run it that's perfect : you have no problem of edges in your geometry!
But even there is nothing that say nothing on the validity of your geometry! ;)
(overlaping etc...)
EDITED: 30 Aug 2020 by PILOU
9928.24 In reply to 9928.23
Oh .. I thought this script helps to detect problem areas, like the one I attached in the answer above
9928.25 In reply to 9928.15
Hi krass,
> There is a question - how to identify such problem areas?
> It doesn't always work visually.
For that one area I used Rhino to help identify it using Explode followed by SelBadObjects.
For the squashed down ones, I used a process in MoI of using Edit > Separate to break the object into individual surfaces, then I clicked on every surface that I could see and after all are selected I then used Edit > Hide to hide those to reveal what was left over. Then it's a process of joining pieces back together without the tiny fragments and looking for naked edges, that can then reveal a few more problem areas that needed to be untrimmed and retrimmed.
Not currently, it is something that I want to add in the future though.
9928.26 In reply to 9928.25
Michael, thank you very much for such a detailed explanation of the solution to the problem!
I will try to follow your recommendations!
9928.27 In reply to 9928.20
Hi WN,
So we need to make sure Krass understands the drill down selections....
So a solid is a single click selection. A solid can have multiple surfaces and edges that make up that selection.
A second click on the selected solid can select "Just a single surface" or "edge" of the joined surfaces and edges that make up the solid....
Those components that make up a solid, as joined pieces, can be "sub selected" (And Named!)....
I believe you know this, but i dont think krass understood this part. Just trying to figure out how to make it clear....
9928.28 In reply to 9928.27
Hi BurrMan.
I modeled it on a cube and made a conclusion on it, but there are different situations.
I think Michael will explain more fully, since I do not know this mechanism and my explanations may be wrong.
9928.29 In reply to 9928.8
Michael, thanks again for your help.
I do not want to create a new topic, I will ask here.
I (I do not know why) began to display invisible inner lines of the object when working. Until recently, there was no such effect.
How to fix it?
System x64, Win10, GeForce RTV 2060 SUPER
EDITED: 3 Sep 2020 by KRASS
9928.30 In reply to 9928.29
Hi krass, that's just a normal type of display artifact that can happen because the display is overall more oriented around doing things quickly rather than having a perfect graphic result. There isn't really anything to fix for it, it's just something to ignore.
In the future I have some ideas for improving it. It probably started to get more noticeable once you had a part with a thin wall thickness on it.
Check out here for some more information:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4987.2
9928.31 In reply to 9928.30
Michael, thanks for the answer!
I will ignore it :)))
Show messages:  1-16  17-31
