New user quick question on Moi3d v4
All  1-3  4-7
Hi Matadem,
MOI doesn't able to do an automatic image tracing as seen in your video.
But, you have two possibilities to have the same thing as in the video.
For logo, personnaly, I do the image tracing with Inkscape which is very good to do it (free and opensource).
Next I export it from Inkscape in pdf format.
MOI3D is able to import pdf format and you will have very good results.
At the end, you could extrude as you wanted.
example :
Another possibility is to use the Max's plugin named "heightmap".
You use a bitmap as grayscale map and heightmap do a serie of curves.
WARNING, the program create a curve (or point) for each pixel in X or/and Y.
Next you could loft curves.
At the end you have to cut unnecessary parts.
You have to choose... But first possibility is best for logos and second is used for more complexe (and less sharp) sources/results.
9927.5 In reply to 9927.4
Good day.
Yes probably I will use inkscape since Affinity designer does not have image tracing option.
The heightmap seems like a good option aswell!
When I saw this technique from 3dcoat I thought this is a great time saver and Moi3d should have this aswell
https://www.youtube.com/watch?v=N4pEdxqKk9c not need to watch the whole video.. the technique is between 4:15 and 4:30min.
Thanks for the info ...awaiting the release as I have many mechanical parts to make :D
EDITED: 30 Aug 2020 by MATADEM
9927.6 In reply to 9927.5
Hi Matadem,
Deriving objects directly from bitmaps like that is more suited to a program like 3dcoat where objects are made up of a kind of soup of lots of little tiny elements like little triangles or voxels.
CAD programs like MoI work with a much different kind of geometry, objects in MoI are made out of NURBS surfaces which are more like broad curved sheets. That kind of geometry definition does not match up well with that type of technique you saw there. It is good in different types of things though like making an accurate model made up of exact spheres and cylinders and such rather than a lot of little elements.
Different programs can use pretty different ways to represent objects and techniques used in one type of environment are not always applicable in a different environment.
9927.7 In reply to 9927.5
Hi Matadem,
3dcoats embossing will be far better and the place you want to do that....
Your cnc package may have the bitmap tracing you are looking for too...... I guess it depends on what you go with....
Show messages: All  1-3  4-7
