Moi <> Blender !
 1-15  16-35  36-55  56-69
9924.56 In reply to 9924.55
Hi Talik,
> Absolutely love OD_Copypaste tool.
> In Moi3D after pasting object, it is always in the center of the scene. Sometimes the
> scale is changing in relation to the model exported from other applications. How can
> this be fixed and objects keep position in the scene and proper scale?
It looks like it's based off of Max's OBJ Import script, you can pass in a parameter "exact" to the paste script to disable the resizing and repositioning.
So go to the keyboard shortcut that you use for the paste, and set up the command part like this:
ODPasteFromExternal exact
9924.57
Hello, its working fine in Moi 5 beta and Blender 4.2.2 except the scale, but i dont understand how to do the 'exact' thing : )
Michael, can you elaborate? I've got 2 new icons and don't use a shortkey. Thanks.
9924.58 In reply to 9924.57
Hi Carlos,
Do you remember how you set up the icons?
9924.59
Hello Michael,
I just followed the instructions - https://github.com/Flowgun/BMOI_Connector/tree/master - and the 2 icons showed up.
Thanks a lot.
9924.60 In reply to 9924.59
Hi Carlos, so go to c:\Users\<username>\AppData\Roaming\Moi\startup and there should be a file there named "97 BMoi.js", replace it with the one attached here.
This one has the "exact" parameter added in to the import button's command.
Does that work?
9924.61
Yes, its working! Thanks a lot, Michael.
9924.62 In reply to 9924.56
It works. Thanks!
I leave here a link to updated OD_copypaste script for Zbrush that will work fine with newer Zbrush versions. For users that would like to use Moi3D and Zbrush connection. The script is in comments below.
https://www.zbrushcentral.com/t/useful-tool-to-copy-and-paste-geometry-between-zbrush-and-other-3d-editors/408590
9924.63 In reply to 9924.60
Hey, that's useful, thanks Michael!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
9924.64
Hi Michael, will it work on a Mac Intel? Thanks.
9924.65 In reply to 9924.64
Hi Carlos,
Are you asking about this one you linked earlier? :
It looks like it's all done with script so I think it should work on Mac as well. But looks like there aren't any install instructions for Mac.
On Mac the MOI appdata folder is located at ~/Library/Application Support/Moi
9924.66
Yes, its working nicely. Thank you so much.
9924.67
This script will save me time in my workflow, maybe a couple of hours per month.
Thanks to everyone involved: Michael, TitusLVR, Flowgun and Max Smirnov.
Agree with Nameless about "export curves from MoI and turn them into bezier curves in Blender".
Carlos
http://moiscript.weebly.com
My Moi French Site
https://schmoll8.wixsite.com/magicavox
My MagicaVoxel Gallery
9924.69 In reply to 9924.68
This is the plug-in/add-on/script I am using to exchange between MOI3D and Blender. Works great.
Show messages:  1-15  16-35  36-55  56-69
