Moi <> Blender !
 1-9  10-29  30-49  50-69
9924.10
I tried but with Wine and Linux not works, for me the best way is via Nurbs surfaces, Blender has a solid nurbs code, that lacks only in the trimmed surfaces.
Below an ICEM surf model imported in Blender.
9924.11 In reply to 9924.10
Wait, wait, wait. Are you saying that plugin moves patches and curves from Moi3d to Blender? That would be insane. This is not a problem to trim all surfaces. Wow! I`m amazed :) I`ve thought that convert nurbs to polygons and moves geometry as OBJ/FBX file. I haven`t known that FBX can handle nurbs patches.
9924.12
seems like I'm getting an error from the 97 bmoi.js file. any suggestions? thanks Val
EDITED: 14 Jul 2021 by VAL2
9924.13 In reply to 9924.12
Hi val,
Are you running an older version of Moi or have you possibly copied an old version of the CommandBar.htm in place of the standard one in the current v4 beta?
That error looks like you are missing the piece of CommandBar.htm that's in v4.
9924.14 In reply to 9924.11
No this example is imported in blender with a special Blender's build, that import 3dm file. here more info about. https://blenderartists.org/t/branch-soc-2014-nurbs-update-to-master/1207889/
But what I suggest is Blender can handle well Nurbs and maybe the best way is using it's own native Nurbs code to exchange file and not the OBJ format
9924.15 In reply to 9924.14
Thanks. I`ve tried it yesterday but I had shading errors even on simple surfaces.
How to use that native NURBS. Are you saying about writing own code?
9924.16 In reply to 9924.15
Yeah because as can see Blender's nurbs are almost ready, in fact with 3dm build you can ready now import 3dm file into blender Nurbs geometry without meshing them. If use only surface modelling with boundary without trimming you can have the same surface inside Blender.
Size: 273.9 KB, Downloaded: 266 times, Dimensions: 829x582px
Size: 213.1 KB, Downloaded: 337 times, Dimensions: 1350x682px
Size: 164.6 KB, Downloaded: 338 times, Dimensions: 1314x658px
9924.17 In reply to 9924.13
Im using the latest beta but I'm using a modified commandbar.htm (it's the one to use the dark scheme I think, I forgot exactly, as too much time has passed since I swapped it out)
Not that it matters that much as I was just curious if the BMOI was more convenient.
9924.18 In reply to 9924.17
Hi Val,
The modified commandbar.htm is the reason for the error - it's because it's a modified older version and so it's missing something that was added later.
You can add in the missing piece by inserting this:
				<span id="CommandBarCustomUI">
				</span>
It goes just after the snap buttons.
9924.19 In reply to 9924.18
Michael,
thanks, worked like a charm,
Val
9924.20
This amazing connector worked v.4 only?
9924.21 In reply to 9924.20
Hi krass,
I think so because the export to FBX needs a newer version of FBX which MoI v4 supports and which MoI v3 doesn't. The FBX import library was updated for v4 and can write newer versions of FBX.
9924.22 In reply to 9924.21
Thanks, I understand!
9924.23 In reply to 9924.16
@pafurijaz: Have you used own code to import that rhino object or that blender build only?
I hope that Blender build will be developed further to have better support of nurbs inside Blender.
9924.24 In reply to 9924.23
Seem something is moving but this part lack of developer, and for now the news are here https://devtalk.blender.org/t/branch-soc-2014-nurbs-update-to-master-code-base-d6807/11681
For the build the now import a mess surfaces, but after saving it can be adjusted with switching off the endpoint of each surfaces V and turning on again the endpoint of both direction U and V. only with this tricks you get out a nice surfaces shading. if you have a model without trimmed surfaces you can import right now without problem, only with wrong options.
Below the direct link for windows Build. the link is still working.
https://blender.community/c/graphicall/vkbbbc/
9924.25
I have this error in Blender when I want to import from Moi3D. Any Ideas how ti fix this?
EDITED: 16 Sep 2020 by SURFERDUDE
Size: 147.6 KB, Downloaded: 202 times, Dimensions: 2558x1439px
9924.26 In reply to 9924.25
Hi surferdude - that error is because Blender doesn't support reading older versions of the FBX format.
In MoI v4 you can solve it by going to Options > Import/Export > "FBX options" and set the FBX version to a newer one.
9924.27
Hey folks here the work in progress of conversion of my Blender 3d model into 3dm file with Moi3d SubD feature, many crashes and the imports was made with few or single mesh and often the complex shapes are splitted in many object in order to avoid the mess generated surface during import, and the model is made for this workflow. and I also gained experience for better modelling with both application.
Size: 357.7 KB, Downloaded: 243 times, Dimensions: 1365x763px
Size: 276.8 KB, Downloaded: 208 times, Dimensions: 1366x707px
Size: 238.6 KB, Downloaded: 163 times, Dimensions: 1366x743px
Size: 234.6 KB, Downloaded: 174 times, Dimensions: 1366x765px
Size: 205.4 KB, Downloaded: 226 times, Dimensions: 1366x768px
Size: 150.3 KB, Downloaded: 209 times, Dimensions: 1365x742px
Very complete model!
9924.29 In reply to 9924.21
Hi Guys,
Just to let you know that with this paid addon "Better Fbx Importer & Exporter" => https://blendermarket.com/products/better-fbx-importer--exporter
you can import in Blender from Moi 3D v3 in fbx format old version.
Supported FBX versions with Better Fbx Importer & Exporter :
FBX53_MB55
FBX60_MB60
FBX200508_MB70
FBX200602_MB75
FBX200608
FBX200611
FBX200900
FBX200900v7
FBX201000
FBX201100
FBX201200
FBX201300
FBX201400
FBX201600
FBX201800
FBX201900
FBX202000
EDITED: 26 Sep 2020 by OKEN
Show messages:  1-9  10-29  30-49  50-69
