Moi <> Blender !
 1-20  21-40  41-60  61-69
https://github.com/TitusLVR/BMOI_Connector (not tested)
image by Stargazer
PS you have the same sort of thing with the free Rocket 3F ! ;)
https://rocket3f.com
EDITED: 25 Aug 2020 by PILOU
9924.2 In reply to 9924.1
Awesome, I will take a look on this. thanks.
9924.3
Looks perfect.
9924.4 In reply to 9924.3
Hi all,
I just wanted to point out that Blender import only works with V4 Beta because only the new version of MoI supports fbx 2016 version. So you need to set the FBX Export settings to 2016.
EDITED: 25 Aug 2020 by STARGAZER
9924.5
Hello Y'all,
I get only a vacant interface stub in Blender:
Somehow there doesn't seem to be much in the BMOI_Connector-master folder of the download.
Is there only one work file in the Blender addon: "__init__.py" ?
I did set the FXB option to 2016 in MOI.
Do I need to set a folder designation in Blender?
Your advice will be appreciated in the extreme.
- MindSet
EDITED: 25 Aug 2020 by IGNITER
9924.6
Looks like you haven't renamed the folder.
2. Extract somewhere and rename extracted folder to "BMOI_Connector"
3. Copy "BMOI_Connector" folder to "C:\Users<username>\AppData\Roaming\Blender Foundation\Blender\2.8x(2.9x)\scripts\addons"
9924.7 In reply to 9924.6
Fantastic!
This is SO GREAT!
9924.8 In reply to 9924.7
Win7 system can also use this plug-in, I tried
9924.9
What is the difference between that and ODCopyPasteExternal? https://github.com/heimlich1024/OD_CopyPasteExternal
9924.10
I tried but with Wine and Linux not works, for me the best way is via Nurbs surfaces, Blender has a solid nurbs code, that lacks only in the trimmed surfaces.
Below an ICEM surf model imported in Blender.
9924.11 In reply to 9924.10
Wait, wait, wait. Are you saying that plugin moves patches and curves from Moi3d to Blender? That would be insane. This is not a problem to trim all surfaces. Wow! I`m amazed :) I`ve thought that convert nurbs to polygons and moves geometry as OBJ/FBX file. I haven`t known that FBX can handle nurbs patches.
9924.12
seems like I'm getting an error from the 97 bmoi.js file. any suggestions? thanks Val
EDITED: 14 Jul 2021 by VAL2
9924.13 In reply to 9924.12
Hi val,
Are you running an older version of Moi or have you possibly copied an old version of the CommandBar.htm in place of the standard one in the current v4 beta?
That error looks like you are missing the piece of CommandBar.htm that's in v4.
9924.14 In reply to 9924.11
No this example is imported in blender with a special Blender's build, that import 3dm file. here more info about. https://blenderartists.org/t/branch-soc-2014-nurbs-update-to-master/1207889/
But what I suggest is Blender can handle well Nurbs and maybe the best way is using it's own native Nurbs code to exchange file and not the OBJ format
9924.15 In reply to 9924.14
Thanks. I`ve tried it yesterday but I had shading errors even on simple surfaces.
How to use that native NURBS. Are you saying about writing own code?
9924.16 In reply to 9924.15
Yeah because as can see Blender's nurbs are almost ready, in fact with 3dm build you can ready now import 3dm file into blender Nurbs geometry without meshing them. If use only surface modelling with boundary without trimming you can have the same surface inside Blender.
Size: 273.9 KB, Downloaded: 266 times, Dimensions: 829x582px
Size: 213.1 KB, Downloaded: 337 times, Dimensions: 1350x682px
Size: 164.6 KB, Downloaded: 338 times, Dimensions: 1314x658px
9924.17 In reply to 9924.13
Im using the latest beta but I'm using a modified commandbar.htm (it's the one to use the dark scheme I think, I forgot exactly, as too much time has passed since I swapped it out)
Not that it matters that much as I was just curious if the BMOI was more convenient.
9924.18 In reply to 9924.17
Hi Val,
The modified commandbar.htm is the reason for the error - it's because it's a modified older version and so it's missing something that was added later.
You can add in the missing piece by inserting this:
				<span id="CommandBarCustomUI">
				</span>
It goes just after the snap buttons.
9924.19 In reply to 9924.18
Michael,
thanks, worked like a charm,
Val
9924.20
This amazing connector worked v.4 only?
Show messages:  1-20  21-40  41-60  61-69
