Micro line cannot get rid of
All  1  2-8
9921.2 In reply to 9921.1
Ok I fixed my own problem. Instead of a full side boolean I made a box around the weird line and just did a boolean diff on that part (see yellow box where I did it), then extruded it back out and the line was gone.
9921.3 In reply to 9921.1
Why do you think you should not use MOI for creating parts?
I did my most recent 3D printer design entirely in MOI.
Frederick
EDITED: 26 Mar 2025 by FCWILT
9921.4
Hello,
The Align command is your friend. Whether you're using additive and/or subtractive workflows, using this useful feature in MoI can prevent you from having these sort of issues when building your model.
9921.5 In reply to 9921.1
Hi Charlie, so that line is a little tiny slivery shelf surface:
When it's deleted the surface above it will still have a little edge in it that used to attach to it, that's why it was kind of hard to get rid of it.
At some point I think I might be able to automatically collapse such things when they are initially created, but that kind of automatic geometry modification is a pretty delicate thing, it's pretty easy for it to end up modifying things that were supposed to be there.
@OSTexo - Yep, I probably use the Align features more than any other tool.
@fcwilt - Agree. I use MoI for designing metal frame fixtures & small CNC machines, as well as 3D printed parts that depend on accuracy.
9921.7 In reply to 9921.3
Glad I'm not the only one creating mechanical parts. I think, though, even Michael might say MOI isn't the right program. Fusion 360 is probably the right one, but I kind of hate it.
9921.8 In reply to 9921.7
Hi Charlie,
You're certainly not the only one using MoI to create parts! I find the combination of its precision, elegant UI and extensible scripting make it a delightful tool to work with. MoI is my primary tool for problem solving, design and creation of construction plans.
--Larry
Show messages: All  1  2-8
