View Shortcut
All  1  2-5
9920.2 In reply to 9920.1
Hi John, there isn't a way to do it on middle click but you can assign this script to the space bar:
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
Then when you push Space it will switch either to the view the mouse is over if you are in split view, or back to split view if there is one view maximized.
That one is listed in the shortcuts section of the help file here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
There are some other various view scripts listed here:
http://kyticka.webzdarma.cz/3d/moi/
These are linked to from the Resources page: http://moi3d.com/wiki/Resources
9920.3 In reply to 9920.2
Thanks Michael. Can you explain how to install this script? Or point me to information on how to do it?
J.
EDITED: 17 Aug 2020 by MOTIONWORKS
9920.4 In reply to 9920.3
<< how to install this script
Just copy it (all code text) in the Right Column of the Options / ShortCuts Keys
And input in the Left Column any Keys (by Pressing any combinaison of keys) : here the Space (write Space if you have only the V 3.0 )
No need to relaunch Moi
9920.5 In reply to 9920.4
Thanks that was super easy!
Show messages: All  1  2-5
