Extrude Function request
All  1-7  8-10
9919.8 In reply to 9919.6
Michael,
RE: 5 : Bool "Cap ends" - True = cap ends, false = leave ends open.
Is there a scripting method to extend cap end options to include single end only.
When extruding closed curves or multiple surfaces, it is commonly desirable that only the projected end be capped, and the base surface be removed.
Forgive me if this question has arisen before. I have done cursory search of the forum before, but was prompted by your recent post.
EDITED: 19 Aug 2020 by JFH
9919.9 In reply to 9919.8
Hi James,
There isn't one directly built into the extrude factory itself but it's possible to make that by extruding with no caps, then using PlanarSrf to build a single cap, transform it by moving it in the extrude direction, then joining the cap with the extrusion.
9919.10 In reply to 9919.9
Thanks Michael,
"extruding with no caps, then using PlanarSrf to build a single cap, transform it by moving it in the extrude direction, then joining the cap with the extrusion."
I am familiar with this approach, although the method of extruding with caps on, then selecting & deleting the base face is a generally less awkward.
It is surprising to me that this feature request is not more common, even if the work around is pretty straightforward.
Thanks again,
EDITED: 20 Aug 2020 by JFH
Show messages: All  1-7  8-10
