Voronoi generator
 1-7  8-27  28-30
9916.8 In reply to 9916.2
The voronoi node does not like the points from the Doyle spiral node.
Will investigate...
9916.9 In reply to 9916.6
Any news ? I looked into node editing and it looks like this takes plenty of time to learn.
I design wheel spokes for my (scooter) bikes and I have plenty of physical labor to do besides the design process.
Any help would be appreciated :)
Size: 2.3 MB, Downloaded: 75 times, Dimensions: 1920x1617px
Size: 728.8 KB, Downloaded: 69 times, Dimensions: 1445x923px
9916.10 In reply to 9916.9
A quick DoyleSpiral node, with centers feeding Voronoi node.
Patterns vary with changing p and q and minMode and maxMode.
There would be a center zone to delete, and lines to delete outside of an outer circumference.
I'm out of posting memory, or would show a png :-(
Geometrical study of phyllotactic patterns by Bernoulli
spiral lattices:
https://onlinelibrary.wiley.com/doi/pdf/10.1111/dgd.12378
This paper has voronoi spiral tilings, etc.
https://arxiv.org/abs/2006.16757
http://archive.bridgesmathart.org/2014/bridges2014-397.pdf
EDITED: 19 Aug 2020 by BEMFARMER
Not an electric bicycle ?
9916.12 In reply to 9916.11
Hi Frenchy Pilou. I am making these scooter bikes with and without electric motors.
I am really just learning how to convert bikes to electric. There is mid motor and hub motor solution, I made one with mid motor and I was not happy with the result.
Now I started a hub motor version, but my problem with wheels that have hub motors that those are tremendously ugly and has just boring good old spokes. So I came up with the idea of making my own custom wheels with custom laser cut or CNC'd wheel spokes. The one you see on the photos is the learner prototype, it's a MoI design that got laser cut from 4mm AlMg sheet then hand bent and assembled with a regular fixie bike wheel hub and rim. I am not sure what's the ToS about outside links, but I will post about it at ... you can google NIORbikes :)
I am getting some good results with Radial Pattern script, using it on a point and then Voronoi pattern, fat lines, extrude . (I only need the 2d lines for laser cutting though)
Size: 506.7 KB, Downloaded: 94 times, Dimensions: 1920x1080px
9916.13 In reply to 9916.10
Thanks Brian, I still haven't figured out how to use nodeediting in MoI3d. I can add and use scripts , but I just need a day or two to sit down and keep doing it until I figure it out. I keep this thread open to come back to it .
9916.14 In reply to 9916.13
Pilou from 2015:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7356.13
Similar fibonacci voronoi from fibonacciSeed script points renamed fiboPts, and run through a simple node.
9916.15 In reply to 9916.12
Thx for the Infos!
9916.16 In reply to 9916.15
I've got to this node editing today. Very interesting stuff. Now I want to figure out how to: Create a set of radial or random points that can be adjusted (like as with _radialpattern.js) then turn it to voronoi, then fat lines then round corners. Maybe it would be too much and it should stop at voronoi?
9916.17
Old, but maybe still viable:
9916.18 In reply to 9916.16
So last month Tudor and Larry did some "get the centers of circles (or arcs)" work:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9875.4
https://moi3d.com/forum/index.php?webtag=MOI&msg=9885.1
_radialPattern script is lacking circle centers.
Larry's CenterPoints script has checkbox option to create the centerpoints of the circles (arcs), say of the _radialPattern script.
Then select the points, and run voronoi script.
So which to pursue? circleCenter script, or circleCenter node and/or radialPattern node, with center output?
Is there an old "get circle centers script" somewhere?
ps, A Doyle spiral with p=1, and q = ~24+, with voronoi applied to centerpoints, makes hexes which are only a little irregular.
EDITED: 21 Aug 2020 by BEMFARMER
9916.19 In reply to 9916.18
Neat to see that the CenterPoints script might be helpful in an entirely unrelated context! The problem I was intending to solve with it is now being better dealt with by a more general Coordinates script that I'm almost done with, so I'll be happy to simplify the CenterPoints script to make it a more general tool for creating the center points and make the export of the coordinates optional. I will also remove the adjustment of the origin and axes as that isn't necessary in this context. When finished, I'll post it here.
--Larry
9916.20 In reply to 9916.19
Hi Larry,
Your modified script will be much appreciated. Thank you
9916.21 In reply to 9916.20
3d printing with: carbon kevlar and fiberglass resin with a polystyrene lining
https://www.3dnatives.com/en/3d-printed-bicycle-helmet-voronoi-190820204/
9916.22 In reply to 9916.20
You're welcome! Much simpler now: no extraneous options, just create points for the centers of selected circles and arcs.
If someone still wants the coordinate values, either follow up with SavePointFile or use Coordinates which creates leaders with either absolute or relative coordinates. Coordinates will be finished soon.
Added a minor modification to the CenterPoints script to check the MoI version as the script uses features introduced in version 4.
--Larry
EDITED: 23 Aug 2020 by FAHNOE
9916.23 In reply to 9916.22
CenterPoints (11) works in MoI4Beta, for circles or circular arcs.
- B
9916.24 In reply to 9916.23
Doesn't work with my MoI V4 beta...
- moritz
9916.25 In reply to 9916.24
Hi Moritz,
Thanks for catching that! I had zipped up the wrong version of the script & thus the error message you should not have received. The correct version is attached in the message above.
--Larry
9916.26 In reply to 9916.25
Hi Larry,
now it works properly ;-}
Thank you
-moritz
9916.27 In reply to 9916.5
Hi Wayne out of interest, can the node editor search the 'workspace' / drawing for a series of points that are already
in place - e.g. node editor checks drawing for all entities with a specific geometry, object name or a certain line color
THEN after these points or objects are selected we run another function on or with those shapes that 'qualified'.
BR Stefano.
Show messages:  1-7  8-27  28-30
