Plug-ins
All  1-7  8-9
9910.8 In reply to 9910.7
Hi Frederick,
> What is the order the folders are checked for commands?
It checks first in the install's commands folder, then if not found there it checks in the appdata commands folder and if not found there it checks in the additional commands that you can give in moi.ini .
> It would seem the user defined ones and the AppData one perhaps should be first so
> any customized commands, like the Dimension one you showed me how to do,
> would take precedence.
Although it would be helpful for that scenario, there's another scenario where that overriding is bad which is when there has been new functionality added into one of the standard commands with a new release. If you take a snapshot of a command script, put it in a central location and have it automatically override the built in one that means that command will be stuck at the version from that snapshot.
9910.9
Create a folder in dropbox.
Copy all plugins into the folder
Create a public dropbox link to the folder
Add it to the resources section here: http://moi3d.com/resources
Done.
When someone uploads a new plugin to the forum copy to the dropbox folder.
Andy
Show messages: All  1-7  8-9
