Plug-ins
All  1-3  4-9
9910.4
Also would be nice if user modifications/customizations didn't require changing anything in the application installation - i.e. MoI looks for plugins in a user-customizable folder (or hard-coded location in AppData).
Andy
9910.5 In reply to 9910.4
Hi Andy,
That is implemented in MoI v4. In v4 MoI looks for commands in the %AppData%\Moi\commands folder in addition to the install commands folder.
It's a good idea to put them there instead, that way they'll be found automatically by new versions and you won't have to copy them around anymore.
There is also a setting in moi.ini where you can put in additional folders to look for:
quote:
Additional command dirs - Add moi.ini setting under [Commands] AdditionalCommandsDirs= which can be set to a semi-colon delimited list of additional directories to look for commands, in addition to the built in commands and appdata commands.
[Commands]
AdditionalCommandsDirs=c:\path1;c:\path2
You have a sort of repository plugins in my site! In French but...
...As there is an image or an animation and the original link...
Menu "Scripts en lignes" and "Les commandes"
https://moiscript.weebly.com
9910.7 In reply to 9910.5
What is the order the folders are checked for commands?
It would seem the user defined ones and the AppData one perhaps should be first so any customized commands, like the Dimension one you showed me how to do, would take precedence.
Frederick
9910.8 In reply to 9910.7
Hi Frederick,
It checks first in the install's commands folder, then if not found there it checks in the appdata commands folder and if not found there it checks in the additional commands that you can give in moi.ini .
Although it would be helpful for that scenario, there's another scenario where that overriding is bad which is when there has been new functionality added into one of the standard commands with a new release. If you take a snapshot of a command script, put it in a central location and have it automatically override the built in one that means that command will be stuck at the version from that snapshot.
9910.9
Create a folder in dropbox.
Copy all plugins into the folder
Create a public dropbox link to the folder
Add it to the resources section here: http://moi3d.com/resources
Done.
When someone uploads a new plugin to the forum copy to the dropbox folder.
Andy
Show messages: All  1-3  4-9
