turning off the transform helpers
All  1  2-9
9905.2 In reply to 9905.1
Options / Disable "Show Edit Frame" ?
9905.3 In reply to 9905.2
Yup, it's the option Pilou writes above which is in the View section of the Options dialog.
9905.4 In reply to 9905.3
Well, that seems to be it ! Thanks :)
On a similar note : is there a way to disable drag-moving, too ? By that I mean the ability to move elements by dragging them directly with the mouse - as this too can interfere with selection, although to a lesser extent than the manipulators mentionned earlier.
Also, a suggestion : Marvelous Designer has a fantastic tool letting one transform straight segments into curves, like so :
https://imgur.com/5qOeAwW
To achieve a similar result in MOI one needs to add one or two new points to the middle of a sgement, select the segments, enable show points, and then dragging the points around. Having the ability to intuitively turn segments into curves like in MD (or something similar) would be fantastic really.
9905.5 In reply to 9905.4
Hi pior,
Sorry no there isn't currently any way to turn off object dragging.
9905.6 In reply to 9905.5
Understood ! Object dragging rarely gets in the way anyways.
Now for something different : I've been running into a strange behavior causing a vertical ruler to appear unexpectedly, even when all snapping options are turned off :
It seems to be similar to what usually shows up when click-dragging from the right side of the main viewport area (as if trying to modify the width of panels), next to the toolbar.
Admittedly my UI is heavily customized so this might be what is causing this ghost line. Also FWIW I am running a 3-monitor setup, so maybe that's a factor here.
This isn't much of a bother, just a bit annoying when it happens. Any idea as to what could be causing this ?
9905.7 In reply to 9905.6
Hi Pior, which version of MoI are you running, is it Jan-21-2020 ? If so try updating to the Jan-22 one at http://moi3d.com/beta.htm . There was a bug in the Jan-21 beta with the new scene browser sizing panel mechanism that was fixed in the Jan-22 build.
9905.8
Ha, that seems to be it indeed ! Just moved to Jan-22 and so far it hasn't shown up again.
Thanks !
EDITED: 18 Aug 2020 by PIOR_O
Message 9905.9 deleted 21 Aug 2020 by MICHAEL GIBSON
Show messages: All  1  2-9
