Summer exercice
 1-17  18-37  38-41
9901.38 In reply to 9901.37
thanks again Pilou a manual process but logical will let you know how the project transpires hoping to make each panel a bolted together plate of steel.
9901.39
Having trouble with this section of workflow - trying to get the intersection of the lines and the planar surface.
Make boolean like this
Select 1 2 Call Boolean Isect 3 4 as "second object set"
(you can of course take more facets in a pass - in your case 7 vertical Quads selection)
that gives the 4 points for PolyLines then Planar...erase not wanted ...etc
But it's an hard work because only "manual"! ;)
EDITED: 23 Dec 2023 by ALEXPOLO
9901.40 In reply to 9901.39
The Boolean ISect are more for see and Keep Surfaces (or Volumes) Intersection!
So
By Default
Just select all lines
Call Trim
Click Plane
Points are shown for info to remove or not but hidden as soon as you valid the Trim!
Re-select the Lines and ask Show Points if you want to see them again for any reasons!
so with your file
EDITED: 6 Sep 2020 by PILOU
9901.41 In reply to 9901.40
thanks for you input Pilou much appreciated will send progress updates as it materialises.
Show messages:  1-17  18-37  38-41
