Summer exercice
 1-13  14-33  34-41
To continue the exploration! :)
Maybe the Flow can be made in one pass...against two here
but as it's so simple like this...
Just to find the Formula of the draft "Angle"
Of course here the Start surface has all planar surfaces!
EDITED: 1 Aug 2020 by PILOU
It appears that drawing a losange between each middle of a no planar rectangle
give a planar surface!
Then with intersection that gives the "rectangle planar" !
and verified by the planar function!
Alas if all rectangles are planar they are not aligned between them!
After it's a big headache maze to make each facet rectangular "jointive"!
After some consuming time! :)
Now all yellow facetts are planar with some functions like Orient Line/line...Trim...Scale etc...
Diagonal alignment is like an optic effect! :)
EDITED: 13 Aug 2020 by PILOU
9901.16 In reply to 9901.15
Problem is to make the alignment between them of numerous facets!
Maybe a trick is existing! :)
The best if of course to make from the begining directly a generative structure of "planar facets"
for avoid all this hand adjustment headache!
Who is not reasonable times consuming!
And here there are just 16 facets...in normal case that is more like 200 - 300! :)
Sorry the file with full alignment facets was not saved in 3dm format (so a good exercice! :)
only in SKP format! :(
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/milieu.3dm (missing top alignment)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/end_precision.skp (full alignment)
A funny thing!
Each Red quad's struture is not "planar...
But losanges (from the middle of the quads as shown above are planar!
If you draw from each middle of a losange a closed polyline so a quad : this one will be also planar!
Triangles resultant are of course "planar" :)
So all elements of the surface under the Red structure is now planar!
EDITED: 20 Aug 2020 by PILOU
A resultant problem for end holidays :)
Does always existing a Point P (x,y,z ) for make 4 planes P1, P2, P3, P4
from vertices A,B,C,D,E,F,G,H given on the 3D space ?
And how to find it ? ;)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/4_plans.3dm
9901.19 In reply to 9901.18
If point P exists, there would be 4 planar faces, P1...P4.
According to the link:
https://blender.stackexchange.com/questions/46113/how-to-make-all-quads-or-ngons-on-your-mesh-planar-2d
"when a vertex has more than 3 surrounding faces, their planar intersection does not necessarily exist - it would be actually very rate if it did:"
9901.20 In reply to 9901.19
But we have intuition that is maybe possible! :)
9901.21 In reply to 9901.20
Point
9901.22 In reply to 9901.21
Sorry i can't Planar this one in your file!
I think it's not possible with your file.
P1, P2, P3, P4 are defined by 3pts for each as all planes 3 points define a plane.
P1 (A, B, H)
P2 (B, C, D)
P3 (D, E, F)
P4 (F, G, H)
The question is : does exist a point P which is on P1, P2, P3 and P4 ?
I think, we have two possibilities to determine it :
1/ Mathematical with a system of equations (each plane is determined by a equation) and its resolution.
2/ MOI (or CAD drawing)
if we do planes P1, P2, P3 and P4 with points A,B,C,D,E,F,G,H with their 3 points, we can do intersections of these 4 planes. If we have only a point... we win and have P !
With your file, the result is a small thetahedron... P does not exist.
My analysis. right or wrong ?
9901.24 In reply to 9901.23
I suppose yes because all edges A to H are "rigid" and that limits variation but in some cases we can make it...
I am waiting answer from a guy who has found a solution but i believe there is an artefact!
EDITED: 21 Aug 2020 by PILOU
9901.25 In reply to 9901.21
@ Rudl
With your file i can make it if i Up "E" on "Z" vertical by 0.05 unity! ;)
I will verify if i obtain the same with the original...
Ok I obtain the same result with the original... 0.05 unity :)
Maybe this distance can be reduced by taking another orientation than the Z vertical line?...
In any case for the moment this point P seems impossible with this given structure!
EDITED: 22 Aug 2020 by PILOU
@Phiro
You seems right...the answer that i was waiting confirm your...there was a similar construction like mine above...
Point P with this structure seems not possible...very tiny but not..we must move slightly point E !
(so some others not shown here) :)
EDITED: 24 Aug 2020 by PILOU
9901.27
Similar project with same workflow for a dome I did a while back.
I used RHINO UNROLL Command to flatten all faces.
9901.28 In reply to 9901.27
3D world is a small planet! ;)
9901.29 In reply to 9901.26
We have to be allowed to dice it up into more than 4 surfaces....
9901.30 In reply to 9901.29
Ah that is a brilliant answer! Bravo...
You have the original structure Yes!
You fill the hole Yes!
You have only planes Yes!
You have not 4 planes but 8 so better twice! :)
And you have only quads Yes!
And there is an infinity of this solution! Excellent!
Burmann's Triangles wins ! ;) Bermuda Triangle ? :)
In situ
More flat
Complete
Now the best will be a little script or Elephant for automatise the down levels
or maybe a tricky use of existing functions (Loft, Sweep, NetWork...) for have directly plane surfaces from false surfaces! (dream :)
I have seen during this little exercise than NetWork has numerous parameters! (Uniform with number of Points...)
By hands it's 20 seconds for the last 4 top quads ;)
For this : here by hands its nothing for 12 quads but when you have 200-300 it's another story :)
It's true Quads "plane" built by external perimeter!
Not like that but...
EDITED: 25 Aug 2020 by PILOU
Ultima days of summer! :)
Found a little trick...
Give a constant base angle...and so possibility to put any length to the segments
so not marvelous but..all faces are now planes! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/last_in_translation.3dm
All blue faces are planar!
Constant angle by row...red faces are not planes! Angle not constant on the red original surface!
Taking the same length for the segment than the red structure...but as the angle is constant by rows... at the end some is missing at the right side! :)
Right side faces are a little deformed but now all yellow volume is quasi wraped!
EDITED: 29 Aug 2020 by PILOU
9901.33 In reply to 9901.15
I am trying to make all faces on this structure coplanar as some are no trying to follow your process but how did you insert the intersecting lines from the junction points.
thanks
Alex.
EDITED: 23 Dec 2023 by ALEXPOLO
Show messages:  1-13  14-33  34-41
