Let's Model a Custom Truck!
 1-4  5-24  25-33
9899.5 In reply to 9899.4
Custom Truck Tutorial Part 4: Lower Cab
The Lower Cab / Hood Assembly is a Network of 4 curves and 5 green profile closed curves. The 2nd green profile has a point at the top to form the hood crease. The circle at the front helps even out the structure where it converges. Network: Lighter.
9899.6 In reply to 9899.5
Custom Truck Tutorial Part 5: Upper Cab
The upper cab is a Network made of 7 curves.
The rounded red rectangle and circle at the top are not connected to the other curves, but their presence influences the network. The rectangle size and position influences the shape of the upper roof line (best to adjust when looking in top view). The circle helps to keep the network from bunching up when it converges at the center of the roof, resulting in a smoother surface. The effect of the rectangle & circle on the structure is easy to see if you select the completed network and Show Points.
Select all the network curves and Network: Mode: Normal This setting gave me the best result.
Next, draw 3 closed curves in side view to represent the window outlines.
Select the cab solid (Be sure the cab network curves are deselected). Perform a Trim and then select the 3 window curves as the cutting objects. Click Done. Select Mode: “Keep” with “Keep All Joined” checked. Click Done again. The cab should remain a solid after this step, and the windows are now individual Faces.
Note: In the prior step, do not select the cab and 3 window curves together, and Trim. That would produce a Mutual Trim, resulting in increased point density of the window profile curves. You’ll likely be adjusting the window profiles to finalize the design, so preserving the original point structure is important.
To Inset the windows, select the resulting window Faces (I had 5 faces because the rear window had a seam down the middle). Perform Offset > Inset 0.6” Inward. It may take a few moments to calculate and show results.
Troubleshooting: If a window fails to Inset, it’s probably because one or more window corner radii are too small, and/or the cab radii are too small. Edit the corners and try again). Also, any small kinks in the window curves can cause a fillet to fail to close, leaving a small sliver of a gap. Show points on the window curves and make sure all segments transition smoothly. Use the smallest number of points on a curve to get the job done.
Verify the cab remains a solid. If not, determine cause and fix it before continuing.
Select the flat “Frame” around each window (shown below in yellow) and Fillet 0.5” Circular to form the window chrome trim.
Select the window Faces and assign a unique color for assigning a glass material in the render program.
EDITED: 29 Jul 2020 by EDDYF
9899.7 In reply to 9899.6
Custom Truck Tutorial Part 6: Truck Bed
Draw a rear profile curve and a side profile curve of the truck bed. Note that the rear profile curve has a straight line across the top, with two Corner Points. This ensures the top face of the bed is Planar which helps when making the fillets later. Boolean Isect the two curves and the result is a solid bed.
In Top View draw a rectangle to represent the bed cavity. Boolean Diff the rectangle with the bed. The result is a hole that goes completely through the bed.
Select the curved rear surface of the bed plus the flat front surface of the bed and Fillet 1.5” G3.
In Back View draw a closed curve that defines the tailgate opening. Extrude (Caps=No) the curve through the back wall of the bed and Boolean Diff with the bed. Delete the extrusion. The result is a solid bed and a solid tailgate.
Select the edges that make the upper, inside perimeter of the bed and tailgate opening. Fillet 0.3 circular. Select the entire tailgate solid and Fillet 0.3” Circular.
Draw a closed curve to represent the flared exhaust opening and mirror to the opposite side of the truck. Extrude the curves (w/ Cap Ends) just past the thickness of the tailgate, and then Boolean Diff with the bed.
Select the edges that make up the exhaust opening and Join to produce a single curve from those edges. In side view, draw an oval 0.5” x 0.4”. Sweep the oval using the exhaust channel curve as the Rail. This produces a solid, lip around the opening. Boolean Union the bed and the lip. Repeat for the opposite side of the bed. The bed remains a solid.
To make the five tailgate "Nomad Bars", copy the rear portion of the curve used to define the tailgate side view and trim it shorter. Draw a closed curve profile of the bar and Sweep it along the curve. Array five of the bars across the tailgate.
To create a recess for the license plate, draw a rectangle slightly larger than the license plate. Fillet the corners 1”, Extrude it forward to create a Solid, and Boolean Diff with the bed. Select the edges around the recess and Fillet 0.3” G3 Blend.
9899.8 In reply to 9899.7
Custom Truck Tutorial Part 7: Hood & Door Seams
The hood and door seams are created using Boolean Merge followed by Fillets on the resulting edges.
In side view, draw a closed curve to represent the cab door opening. Draw an open curve to represent the hood opening.
Select the Upper and lower cab, and Boolean Merge with the two curves. The lower cab is now 3 solids and the upper cab is 2 solids.
Select the 3 lower cab solids and Fillet 0.14” Const Distance.
Select the door & door frame edges on the upper cab solids and Fillet 0.14” Const Distance.
That's almost everything. Finish by making some door handles, rear bumpers, exhaust pipes, running boards, front grill, and headlights.
Have fun!
9899.9 In reply to 9899.8
Really cool tutorial :D
Would love to see another one in a more modern style car!
edit: Really appreciated the article style tutorial that's getting rare in the internet. The quick pacing of youtube tutorials and the lack of clear concise descriptions sometimes makes learning hard. Not to mention also quality of audio.
Cool !
I put it in hurry on my Moi Site ...
...after your https://moiscript.weebly.com/la-voiture-de-ed.html ;)
So let's start ;)
https://moiscript.weebly.com/le-truck-de-ed.html
EDITED: 29 Jul 2020 by PILOU
9899.11 In reply to 9899.8
excellent ! thanks for sharing !
It's really cool Ed, thanks for making the tutorial!
9899.13
Very nicely done! Thanks Ed!
9899.14 In reply to 9899.13
Excellent, these types of tutorials nicely represents the right thinking during the process of transformation from curves to solid/surface in MoI.
Thanks for sharing.
Mik
9899.15
That was AWESOME! Thanks for sharing.
Message 9899.16 deleted 21 Aug 2020 by MICHAEL GIBSON
(spam deleted)
9899.18
Very nice tutorial, Ed, many thanks for sharing.
I really need to use Network more often. It's quite powerful.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
9899.19 In reply to 9899.1
this is just what i was looking for. there are so many modern car modelling tutorials with the generic audi body shape that doesn't address the challenges of 50s car modelling.
tho in the 50s every year was unique.. now its almost like every years the same.
id love to see you do a 1959 cadillac
9899.20 In reply to 9899.19
Thanks mrjynx - I hope the tutorial was useful.
As much as I like the 59 Caddy, modeling existing cars holds no interest for me. I prefer to blend features I like from several cars into a custom creation. That comes from growing up in Los Angeles in the 60's where every weekend, custom cars from miles around cruised the boulevard. It was like the movie American Graffiti on steroids.
Lately I've become interested in European cars from the 1930's. We called them "Big Fender Cars". They are true works of art.
Watch for a tutorial coming soon!
9899.21 In reply to 9899.20
Great tutorial, Ed, thx for sharing !
I'm a great fan of 30s and 40s Military U.S. trucks,
Fords, Chevies, Dodges, Studebakers and "Jimmies" (GMCs).
Looking forward to your next tutorial !
Oliver
o5m6.de
Beware of the hun coming out of the sun ;-)
9899.22 In reply to 9899.20
Would love to see a tutorial on a Delahaye or Duesenberg/Aubrn/Cord form the fat fender era...
I too love the early years of American hot rodding and those traditional styled hot rods. Not much into street rods but some rat rods remind me of the trad styled hot rods.
In the early 1960s I would clutter the family kitchen table with the parts from a 1/24th Monogram or 1/25th AMT, Revell, MPC, Johan, Aurora plastic car model kit much to the chagrin of my Mom who was trying to set the table for super.
In 1983 I restored a 1960 Corvette which I still own and take for a pleasure cruise on a sunny summer's day in Nova Scotia.
Great tutorial & many thanks.
9899.23 In reply to 9899.22
Hi Kenmo, I love the 1960 Corvette!! And other 1960 cars too like even Volvo has that really cool compact for 1960! :)
9899.24 In reply to 9899.22
KENMO says, "Would love to see a tutorial on a Delahaye or Duesenberg/Aubrn/Cord form the fat fender era..."
KENMO, have you been looking over my shoulder the last couple of months? :) I love "fat fender" cars.
I can't give a specific time, but the model is essentially finished. Doing renders and the write up takes time.
I'll probably post a partial teaser shot as I get further along.
Keep your eye on the MoI forum :)
EDITED: 21 Aug 2021 by EDDYF
Show messages:  1-4  5-24  25-33
