Boolean Diff leaves holes in planes, not object
All  1-5  6-8
9895.6 In reply to 9895.5
I don't have that object type dialog in the upper right, but I'm using an older version.
I think it's obvious it isn't a closed solid. But I'm not sure how to fix it.
Maybe I need to redo the model, and be more careful constructing it out of solids, instead of building-up parts of it from surfaces.
-Kevin
9895.7 In reply to 9895.6
you need to build missing faces ( with networks )
copy paste the 2 circles ( to trim later )
I delete the two faces with circles ... select the four borders ( don't forget to join the segments of each border ) and apply Planar ( to prevent possible gaps )
join the 6 faces of the piece ( it says Solid ... good for booleans
paste + trim the circles and the flat faces ( then you can delete the round disks )
and loft between the two circles
finally copy all faces included the round surface ( the loft ) and paste elsewhere ... then join to have a solid
( I work on the half piece and do a mirror + boolean union )
3dm file joined
EDITED: 9 Sep 2020 by CORCHET
9895.8 In reply to 9895.7
Thanks, this is helpful. I will try to repro the repair steps, and keep things as object in my workflow.
Show messages: All  1-5  6-8
