Node Editor • Rotation Range
All  1  2-7
9893.2 In reply to 9893.1
I am affraid that Chamfer is not implemented!
You must simulate it! (Boolean Diff for example)
or maybe this (no time to test now :( (working without node! So I am confident ;)
Edit : Tested! Seems that is working only on a Volume, not only on edge(s) or surface(s)!
Better than nothing! :)
For the random : https://moiscript.weebly.com/basic.html#biberandom
EDITED: 19 Jul 2020 by PILOU
9893.3 In reply to 9893.1
Tim
"angles between 200° - 290°? So it would basically be a node network that would allow me to randomly rotate an object within a rotational limit (range)."
Try the nod file below, & let me know if this works for you.
Otherwise I can change to suit your needs.
EDITED: 19 Jul 2020 by JFH
9893.4 In reply to 9893.2
Thank you for your kind response Pilou, I appreciate you sharing your knowledge! :)
Using the Fillet2 node is definitely something that I will use in my workflow. Thanks again for taking the time to experiment and share your findings.
Shame about the chamfer, but there are plenty of workarounds. ;)
Kind regards,
Tim
9893.5 In reply to 9893.3
Hi there James,
Once again you have absolutely nailed what I was trying to achieve! Thank you so very much for kindly sharing your time and extensive knowledge. I really do enjoy studying your node circuits and have already learned a great deal from the many times that you have shared your fantastic node networks. I got pretty close with this random angle experiment, but just couldn't get it to remain within a range. I can see that the math node is pretty essential to achieving this.
Thanks again James, I am always grateful for your time and effort.
Kind regards,
Tim
9893.6 In reply to 9893.5
Tim,
It occurred to me that this could simply be achieves with Point/JitterPts node.
Perhaps this may suit your purposes better.
9893.7 In reply to 9893.6
Hi James,
Thank you so much for kindly giving this additional thought. Your posts are always like Christmas morning gifts for me! :) Again, I am most grateful for you sharing your knowledge, I always learn so much from your fantastic networks. I learned a great deal from your previous solution and now better understand the math node that you used. Quite a brilliantly simple solution to use a multiplier on the randomly generated number (0-1) x the rotation amount, added to the minimum rotation angle (in a clockwise rotation)! Great fun learning these techniques and imagining the endless scenarios archievable. This JitterRotate looks great! I love the Jitter node and the happy accidents that can be generated with it.
I really like this simpler alternative James, thanks again, always super-grateful for your educational solutions!
Stay safe and happy Noding! ;)
Tim
Show messages: All  1  2-7
