Node Editor - How to Rotate
9884.1
I would like to be able to select an object and the center of rotation using the mouse and have these values as input to the Node Editor "script" - see attached.
Right now the center of rotation is hard coded to verify that rotation using the slider worked but I don't know how to set these values via a point selected with the mouse.
Thanks.
Frederick
EDITED: 26 Mar 2025 by FCWILT
9884.2 In reply to 9884.1
9884.3 In reply to 9884.2
Sorry but I still don't see how to set the X,Y,Z values of a Point node by selecting a location with the mouse.
Thanks.
Frederick
9884.4 In reply to 9884.3
Hi Frederick, I don't think there is any method set up in the node editor to pick a point with the mouse like you would in a regular MoI drawing command.
You would probably need to create a point object using Draw curve > More > Pt and then feed in that point object.
9884.5 In reply to 9884.4
OK I will see if that is doable.
Thanks.
Frederick
9884.6 In reply to 9884.5
Hi Frederick,
The pointcoordinates script might help with picking a point, and getting the XYZ coordinates.
https://moi3d.com/forum/index.php?webtag=MOI
I am unsure what kind of interface with nodeeditor would work...
I suppose the rotation axis (Frame) would depend upon the active view? Top, Front, or Right. (or 3D?)
What sort of widget node would permit mouse input to a .nod file?
9884.7
Hello Frederick,
preselect the point object in moi and create a new point in the node editor with points2\Point. This node will take the coordinates of the selected point object. To see the point you can connect a point in NE with Info\showFrame.
Hope that helps!
Have a nice day
Karsten
9884.8 In reply to 9884.7
Hi Karsten,
Thanks for the help.
I got it to work.
If I move the Point Object is there anyway to update the Point Node other than removing it and creating a new one?
The Selected Node used to select the object to rotate has the Clear/Update options but the Point Node does not.
Frederick
9884.9 In reply to 9884.8
Hello Frederick,
sorry - no it's a one way ticket. The idea is to get it's geometry in the node editor and work then inside it.
Karsten
9884.10 In reply to 9884.9
Thanks for the info.
Frederick
