Is there a way to avoid having sharp edges (Kayak edges) after you join two surfaces created using network?
All  1-4  5-14
9881.5 In reply to 9881.1
Hi DrillBit, can you please post your .3dm model file?
Usually the best way in MoI to avoid sharp edges is to make one single larger Network instead of doing it in smaller sections. If you do it in sections you will end up with sharp corners between each section.
9881.6 In reply to 9881.2
Hello Phiro,
thank you for your reply and I am sorry for my late reply!
No, I cannot post my file! I am using a trial version of Moi3D with no saving! The reason I am doing this is that I want to get familiar with it, currently I am a user of SolidWorks (it is the main modeling software in our office) However, I had the chance to meet with Moi3D and I really liked its speed or its philosophy which is built around speed! :-)
I just want to become sure of its capabilities so maybe I will switch to as main concept modeling tool in the close future.
I have created these images to help you to see my process. :-)
EDITED: 25 Jul 2020 by DRILLBIT
9881.7 In reply to 9881.4
Hello and thanks for your reply Ed(EDDYF) and sorry for my late reply,
by "kayak" I meant sharp edges if you find the attached images in my reply for Phiro you can see my question in pictures. :-)
And thanks for your informative reply :-)
9881.8 In reply to 9881.5
Hello Michael,
Thanks for your reply and sorry for my late reply.
If you find the attachments in my reply for Phiro you can see my question in images. But I think u answered it already! so, I will ask you a new question How to create one large Network? just by mirroring my curves? Is that it? Well I will try it as soon as possible. :-)
9881.9 In reply to 9881.3
Hello Bemfarmer,
Thanks for your reply and sorry for my late reply! :-) I was kind of busy.
If you find the attachments in my reply for Phiro you can see my question in pictures!
9881.10 In reply to 9881.6
Question 1 : You right : for be tangent you must have Control Points Aligned
Maybe you can use these free one for post your images! ;)
https://imgbox.com
Use the "Full Size" then copy a part of the link (BB Code) with a little change
[IMG]https://images2.imgbox.com/ad/18/s4CjL47H_o.jpg[/IMG]
becomes for this forum (without the " " after the "<" )
< img src="https://images2.imgbox.com/ad/18/s4CjL47H_o.jpg"/>
so
EDITED: 25 Jul 2020 by PILOU
9881.11 In reply to 9881.10
Hello PILOU,
Thanks for your reply, I have successfully edited my post now I think you can see the images with ease.
Thanks for the info.
9881.12 In reply to 9881.5
Hello Michael,
I tried to use one single large network but either it took never ending calculation or failed to calculate or created a weird shape!
9881.13 In reply to 9881.12
Hi Psygorn, so yes your curve tangents are all set up like you thought. The problem is that will only make the network surface to be tangent at those particular spots. At the interior areas the surface shape will be a kind of blending of all the curves. You can kind of get a feel for this if you turn on surface control points.
Sweep can be better for this type of shape instead of Network, especially for a 3 sided layout.
I've attached an example file, if you load the file SweepTangent.3dm you can select this curve for the profile:
Then these as the 2 rails:
Then enable the "Maintain tangent" option:
A sweep made with that option will keep all the cross sections generated for the sweep to be on parallel planes, like this:
This kind of construct then has the full surface to be tangent at the centerline, so it can be mirrored ok:
If you turn on surface control points for the Network you can see that the generated surface won't have that kind of sections on parallel planes type structure, it will be influenced by things like the different lengths of the curves.
To use Network it's making a weird shape because for Network the curves have to form a regular 2D grid, sort of like a set of latitude and longitude lines, so you'll need to join together some pieces so it has that type of layout. So for your case here that would be like this:
If you open the attached NetworkExample.3dm file and select all the curves and then run Network that should work.
Another layout that would work for Network is to have these 3 as separate curves, and then the bottom one joined together, then that makes a Network with the "pole" at the tip:
If you turn on surface control points for each of these Network results you'll see that on the first one there are "poles" at the ends, and the other one has one "pole" at the top:
The result you were getting that was chaotic or didn't finish calculating is because Network was not able to get a regular "latitude/longitude" layout from those curves.
Hope this helps!
9881.14 In reply to 9881.11
Yes we can see them, but they are some bigger! :)
That is curious because I have this option enabled on the Forum option ?
"Resize images and reflow page to prevent horizontal scrolling."
PS Curious that works now when i reload the page!
So all is ok ! :)
Show messages: All  1-4  5-14
