Question about dimensions
All  1  2-6
9866.2 In reply to 9866.1
Hi Frederick, dimensions are projected onto the current construction plane. You can set the construction plane by using View > CPlane, if you set it so the cplane's origin point is on that surface plane then they will go on there when you draw a new one.
When you're done you can right-click on View > CPlane to reset back to the default world origin/world axis construction plane.
When you place the construction plane for this type of purpose, you probably will want to disable the "Align to objects" checkbox option:
9866.3 In reply to 9866.2
Thanks for the reply.
That explains what I was doing wrong.
It's a bit tedious when placing a lot of dimensions but I don't see how it could be made easier.
Perhaps I can find a way to assign setting the c-plane to one of my unused mouse buttons.
Thanks again.
Frederick
9866.4 In reply to 9866.3
Hi Frederick, if you want to set up a shortcut key for it, put in this for setting the CPlane:
script: moi.view.setCPlaneInteractive();
And this for resetting it:
script: moi.view.resetCPlane();
I originally had the dimensions go on a plane parallel to the cplane but through the first point that you pick. But that can be bad in other situations, see here for some previous discussion:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9526.62
That also shows how you can modify the dimension command if you want to make it behave like I think you were originally expecting.
9866.5 In reply to 9866.4
Thanks very much for the link.
Yes that alternate behavior is like what I was expecting.
The issue with placing a dimension from one object to another does not seem like it will be an issue for me in the majority of situations. It's easy enough to work around.
Perhaps a "check box" could be placed on the "dim" panel allowing a quick selection of the two behaviors. This might satisfy most everyone and still allow manual placement of the c-plane as needed.
Just a thought.
Frederick
9866.6 In reply to 9866.5
Hi Frederick,
> as needed.
It will probably end up like that, I kind of want to wait and see a bit how often it comes up.
Show messages: All  1  2-6
