Node Editor • Mirror Node Problems
All  1-2  3-14
9864.3 In reply to 9864.2
Hmmm thank you Pilou, I appreciate the kind feedback.
Not quite what I was trying to achieve, as I would prefer to mirror across the center of another object, rather than a random slider amount.
I would like to be able to achieve this result, but using the Node Editor.
Thanks again! :)
9864.4 In reply to 9864.3
Ummm this makes no sense? Why the random angle?? Definitely not mirroring with any logical sense? lol
9864.5 In reply to 9864.1
Hi Tim,
> I know that the mirror function outside of Node Editor requires
> two points to mirror on (on any axis)
It's not actually just 2 points that set up the regular mirror command, it's 2 points _on a construction plane_ . The regular command picks up the plane implicitly from the viewport where you pick the 2 points. So it's actually 3 things are input with the regular mirror command - a coordinate frame (origin point and x,y,z axis directions) plus 2 points in the x/y plane of that coordinate frame. It actually bundles these up as 2 things since it takes the coordinate frame's origin as the first point also.
Looking at the code for the mirror node in transform2.js, it looks like it is expecting to get a coordinate frame for the input and then it's the x-axis line of that coordinate frame that is used as the mirror line.
So to get it to mirror in some other direction that then world x axis you have to give it a coordinate frame that has its x axis direction oriented along the mirror line. I'm not sure how that is done though, there is a FrameByVecs node which takes xaxis and yaxis directions but I don't know why it doesn't also have an origin point input as well.
9864.6 In reply to 9864.3
Edit : In fact that works but you must draw the line on the top Plane of the Object! (and fareaway)
EDITED: 4 Jul 2020 by PILOU
9864.7 In reply to 9864.4
Hi Tim,
Well it's going to call the getFrame() function on what is given to the MirrorFrame input. That's located in geometry.js but I'm not quite sure what it's trying to do with other kinds of input like single vector like you're giving it. Maybe that's taken as the z axis direction of the plane.
Message 9864.8 deleted 4 Jul 2020 by TIM_WHITEMAN
Hi Tim, you may have missed my replies above since we were posting at the same time. I think the problem is the mirror node is expecting a coordinate frame but here you're giving it a single vector. I'm not sure what it cooks up for the coordinate frame for that case but possibly something like generate a plane with that vector as the z axis, then the mirroring is going to happen in the x/y plane around the x-axis direction.
Seems there is a glitch for the X axe :)
9864.11 In reply to 9864.9
Many thanks for your kind insight. Definitely very confusing and I'm still not quite achieving the results I'm looking for despite yours and Pilou's great support.
I'll keep experimenting as you've mentioned and see if I can find a solution.
At the moment, it keeps only mirroring on the Z axis, but I'll try some different scenarios to see if I can troubleshoot it.
Thanks again, really appreciate your time and attention.
Tim
9864.12 In reply to 9864.11
Hi Tim, so the thing I'd be looking for is something that generates a coordinate frame object.
I'd think there would be one that would take an origin point, x axis direction, and yaxis direction but maybe that's missing right now. FrameByVecs looks close though.
9864.13 In reply to 9864.10
Ahhh, yeah, I thought there might be a problem with it as I couldn't get anything to work across the X axis at all no matter what I tried.
Thanks for your great suggestions Pilou, I do appreciate your time and attention. You got slightly closer to what I am trying to achieve with the GetCrvSFrame node ;) Just can't get it to do it on the X axis!
Thanks again Frenchy Pilou! :D
9864.14 In reply to 9864.12
That's a great suggestion Michael, thank you! I'll give that a shot and might have to think of some workarounds. I did try a negative Scale1D in the Node Editor, but sadly it doesn't scale in the negative (X scale -1), which would've been a great solution. I'll definitely take a look at FrameByVecs though.
Tim
Show messages: All  1-2  3-14
