Keyboard Shortcuts two computers
All  1-2  3-9
9862.3 In reply to 9862.2
Great Thanks will try it . I never work simultaneously in two computers , using laptop when away from home.
9862.4 In reply to 9862.3
<< I never work simultaneously in two computers
You can't!
But you can lunch any number of sessions on the same computer following your hard memory! ;)
9862.5 In reply to 9862.1
Hi brane, yes if copy over your moi.ini file that will bring all your shortcut key definitions over. You can find out where the moi.ini file is located by using Options > General > "Edit .ini file" button. That will put up a dialog box that tells you where the moi.ini file is located at.
If you have installed any plugin-ins by copying stuff into the commands folder you'll also need to do that on your other machine as well.
9862.6 In reply to 9862.5
thank you Michael, That helps !
9862.7 In reply to 9862.4
here is mine everything is hand drawn using perspective grids ,no 3d yet but soon i hope. https://www.facebook.com/danic.branko/
9862.8 In reply to 9862.7
Really cool drawings brane!
9862.9 In reply to 9862.8
Thanks Michael! Moi feels fluid almost like i ' m drawing but i don't need to worry about perspective.
Show messages: All  1-2  3-9
