keyboard shortcuts for dummies
All  1-3  4-12
9861.4 In reply to 9861.1
Hi brane, do you mean you are installing a plug-in and you want to set up a keyboard shortcut for it?
If you are still stuck, please say what plug-in you are installing and that will help to give you some specific information for how to set it up.
Also setting up shortcut keys is a little easier in MoI v4 than in v3, in V4 when you set up a new shortcut key you can just push the shortcut instead of needing to type out its name like you do in v3.
9861.5 In reply to 9861.2
Thank you! getting the hang of it!
9861.6
thank you Pilou, Farmer and Michael! That helps, im getting the hang of it!
Thanks for the fast response , i appreciate very much for your help!
For have an idea of the shortcuts of Blender! :)
9861.8 In reply to 9861.7
Well that is clear as mud.
Is it supposed to be humorous?
Frederick
9861.9 In reply to 9861.8
Of course! :)
Problem of all Shortcuts of any program is the memorize of them!
I can't memorized more than shortcuts 5 by prog and I use maybe 20 - 50 progs for the fun so...any tricks is fabulous!
(for me)
9861.10
What is the command line command for BooleanIsect? I have been trying to create shortcuts for Boolean operations and I have managed to do this for the other commands but not for Isect.
Ctrl+1 - BooleanDifference
Ctrl+2 - BooleanUnion
Ctrl+3 - BooleanIsect ?
Ctrl+4 - BooleanMerge
9861.11 In reply to 9861.10
Try with "Intersect" ? No it's not : that gives the intersection curves of volumes...:)
it's "BooleanIntersection" :)
You can test by Press Tab then write your function without space
like Circle, CIRCLE, CirclE etc...
EDITED: 2 Jul 2020 by PILOU
9861.12 In reply to 9861.10
Also there is a list of command names here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
Show messages: All  1-3  4-12
