Trivial but...
All  1-8  9-14
Message 9857.9 deleted 17 Jan 2021 by WAYNEHILL5202
9857.10 In reply to 9857.8
@ Michael OK I can understand that...
Of course will be more easy to make the boolean then kill caps if this result is wanted.
All that was not clearly evident (for me ;)
Thx for the clarification!
Here with a Boolean merge (must caps killed)
EDITED: 27 Jun 2020 by PILOU
9857.11 In reply to 9857.9
@Wayne No it's a sort of intersection of volumes who is wanted not a trim by a plan! ;)
The trim was well realised
it was just the specific result that i wanted (hollow without caps )
that was not success in one operation...(by me :)
9857.12 In reply to 9857.11
@Pilou,
Ok. Downloaded your sample. Boolean unioned all parts, created a jagged trim line by selecting the intersect lines between the halves and joined them as a jagged trim line. Selected the solids, and trimmed by the jagged intersect line. Pulled them apart and a middle section appeared between the two halfs. You looking for a clean divide. Got it.
Wayne
9857.13 In reply to 9857.12
See my other solution above when you post your! ;)
Another solution (in fact that is that I made for my first image of the thread;)
but curious tearings appear during the Boolean union!
here second volume is move down a little before the Boolean for have a more sinuous intersection!
Select the 2 volumes Curves Isect
Boolean the 2 volumes
Trim by the curve (from Isect)
Result that I want (except the artifacts (?) )
Artefact are not yet existing when I make some rendering
here with the very easy and free CadRays who accepts Step and IGES from Moi ;)
https://www.opencascade.com/content/cadrays
Show messages: All  1-8  9-14
