Just discovered Node Editor
 1-5  6-25  26-39
9845.26 In reply to 9845.25
Hi MAYSKY,
Link to the 3 versions that I did, 3 to 6 whole years ago. I have not reviewed the notes from back then,
but there is a difference between instantaneous initial and terminal pitch, and the pitches for the first and last turns.
https://moi3d.com/forum/index.php?webtag=MOI&msg=6697.11
Maybe I'll try to do a node. Due to being busy, no work has been done for the last 4 months :-(
EDITED: 24 Jul 2020 by BEMFARMER
9845.27 In reply to 9845.26
Thank you Brian,
I hava found and downloaded Two; “_VarPitchHelixExtremes” and “_VarPitchHelixVerbose”. Poking around I discovered what may be node! ... VarPitchHelix.nod it was by Barry-H in a post to you. (7777.374 In reply to 7777.373 ) form May2017.
I have not had a chance to play with anything yet.
I would truly love to be able to have a node or script that can construct a variable pitch helix that can follow a curved path as its main axis. Ideally the curved path is in the form a variable pitch helix. Like a macro in a macro or some such analogy.
Algorithmically speaking, do you think it’s possible?
9845.28 In reply to 9845.27
Hello Maysky,
here is an example how you can create such things without a special node. The point is that you can create special things by yourself;-)
Have a nice day
Karsten
9845.29 In reply to 9845.27
Kudos to Barry, Karsten, and Flow.
-♤♡◇♧ Brian
(Discovered extra symbols on Tablet)
9845.30 In reply to 9845.28
wow!!!
Thanks heaps Karsten.
Will need some time to understand. but WOW!
9845.31 In reply to 9845.28
I am trying to get a grip on NE by following some (basic) projects in the Elephant Repository
(9 Oct 2019  (301 of 441) 9476.301  ) using “ProjecMP.nod” from Karsten
I have tried to recreate a post from Pilou:
But it seems I have missed some basics!
Nothing I have tried In and Out Progenitors and setting up a blank Macro to house the ProjectPM node is giving me any result. I cannot even save the setup. See attached images
On the other hand “Helix2Helix.nod” also from Karsten macro runs no problem with no In Out progenitors.
Size: 157.4 KB, Downloaded: 23 times, Dimensions: 686x721px
Size: 214 KB, Downloaded: 17 times, Dimensions: 800x866px
9845.32 In reply to 9845.31
Better to post your "file .nod" & "file.3dm"
From your second image you have nothing in Selected Objects Nodes ! (0)
Red = Not connected or Node missing
Look at this copious page! :)
https://moiscript.weebly.com/node.html
For Selected something for a Node
Selected that you want on the Moi's screen then Right Click on the Node Selected / Update
(repeat on each node if necessary)
Then Run
EDITED: 26 Jul 2020 by PILOU
9845.33 In reply to 9845.32
And thank you, I did not know how the select object worked.
So I selected the object and target did but the macro remains red and I am not given an option of saving the m”myfile.nod”
so ill repost the “ProjectMP”. It might me broke? Its main nodes are red.
Size: 53 KB, Downloaded: 13 times, Dimensions: 765x536px
9845.34
Hi Brian, Pilou Karsten and Michael G,
Thanks for all your help
I had a play with Barry’s VaribleHelix.nod and could not get it to run.
I read Brian’s pdf on his Variable Pitch Helix script. And had a play with the scripts in MoI.
They work beautifully.
I am trying to get my head around the Maths to possibly adjust Karsten’s Helix2Helix.nod.(if ok with Karsten)
Adjustment 1: The major helix to have a variable radius.( Looking at Helix2Helix, I cannot work out where the Second radius needs to be inserted)
Adjustment 2: The minor helix to have variable pitch and radius. (Replace the standard Helix-node with a Variable-Pitch-Helix-node-bundle from within Karsten’s macro )
Adjustment 3: Major and Minor Helix to be independently Left and Right handed. (swapping Sine and Cosine. But I am lost, truly :(
Comparing the Script Maths and the Node Maths I did notice the similarity:
x(t) = (R1 + R2*t) * sin(360*Num_turns*t)
y(t) = (R1 + R2*t) * cos(360*Num_turns*t)
z(t) = N * (p1 * t + p2 * t * t)
from Brian’s script and:
c*cos(PI/a*b)
c*sin(PI/a*b)
from Karsten’s node which, I think, uses a Progression node as the z(t) equivalent
So that’s where I’m at...
Any help would be greatly appreciated.
9845.35 In reply to 9845.33
Your Macro makes nothing
And I am not sure that is a good idea to put the selected objects inside...
that oblige to go inside for input the objects!
And are you sure to give the good Nature of Output (inside the Macro) ? ( Numbers, Points, Objects)
( Choice given by Right Click on the OutPut )
9845.36 In reply to 9845.34
In addition to Pilou's excellent documentation:
There is a wiki section on the NodeEditor in the MoI Home Resources section of the forum.
This includes some documentation of Macros: http://moi3d.com/forum/index.php?webtag=MOI&msg=9189.1
9845.37
Is there a node(s) that can plot cylindrical/polar coordinates using: Radius(t), Angle(t) and z(t), instead of the Point-node which maps Cartesian x(t), y(t), z(t) coordinates?
I managed to create a Variable Pitch - Variable Radius (vP-vR) Helix NE macro attached here
Thanks to Brian’s instruction pdf and his VarPitchHelixExtremes.js script.
Having difficulties Flowing a custom Helix over another custom Helix.
(Red line is the minor helix)
Can only Flow the MoI Factory Helix-Node onto another Helix.
I am hoping that using cylindrical coordinates to describe the Minor vP-vR Helix will make it easier to ‘Flow’ it over another Helix? As there would be a centre reference for the axis to follow.
Any other suggestions are welcome.
9845.38 In reply to 9845.37
After a very brief peek, the FLOW Base for your first .nod appears to be very short, 10.4 units, versus 200 for the second node.
9845.39 In reply to 9845.38
Thanks for your help and patiens. I think I’m finally getting the hang.
Could not have done it without your scripts, documentation and answering my stupid questions.
Just one more, if ok with you.
How did you work out what to do with the [t=i(numPoins-1)] and [R2 = UserEnteredValue – R1]?
Without me following your Scripts, I would never have worked that out.
Show messages:  1-5  6-25  26-39
