Just discovered Node Editor
 1-9  10-29  30-39
9845.10 In reply to 9845.9
Your node works without problem in the Beta V 4!
9845.11 In reply to 9845.7
Hi geoff, the nodeeditor is Max's part time side project that gets updates when he has extra time. It's somewhat of a community project and has a slow rate of development.
If that type of procedural modeling is an integral part of what you need, you would probably be better off with Rhino/Grasshopper, although if you are interested in community based open source development and would like to participate in evolving it then it might be a good fit for you.
Existing nodeeditor users are using it with the MoI v4 beta and so there are some bugs when using it with v3.
I think I recognize the second one you show as a bug when creating a Macro when running under MoI v3, there is some info on that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1494
I'm not entirely sure but I think the other 2 are also things that use newer areas of Javascript which are not supported by the older WebKit version that is bundled with MoI v3 but are supported on the newer one that comes with MoI v4.
Else if you want a crazzy nodes system free on line take also a look to this!
https://cables.gl
or
EDITED: 30 Jun 2020 by PILOU
9845.13 In reply to 9845.7
Hi Geoff,
The imgsampler, voronoi, delaunay nodes are developed using MoI V4 Beta and the latest Node Editor version.
The ImgSampler error could be an input value is not set for scale. Or the image is missing. I did not add error checking for all possible scenarios.
Using scripting for balustrade would be ideal. ( I had to look up balustrade on google. ).
- Wayne
EDITED: 1 Jul 2020 by WAYNEHILL5202
9845.14
Thanks for all your assistance. I am still playing and making progress in understanding how it all works.
9845.15
Hello,
Installed the nodeeditor.v.1.1 It opens ok. Read the
“MACROS IN NODEEDITOR.pdf”
But cannot work out why I cannot do anything with imported macros.
How do i apply the "progenitor input and progenitor output"
Found the “Extensions: Curves2” on [https://moiscript.weebly.com/curves2.html]
Which I would like to access and experiment with the helix function, but the links just go around in circles
Could somebody please point me in the right direction?
EDITED: 24 Jul 2020 by MAYSKY
9845.16 In reply to 9845.15
if you load this one by James
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
it must be have the last version of the Node Editor (even I suppose it's written 1.0 (?) )
Wait the answer of James for confirmation
In any case with it the Helix function works fine exactly like that you found here
https://moiscript.weebly.com/curves2.html#helix
For the Macros takes a look here
https://moiscript.weebly.com/macro-e.html
Needs an entrance (In) and an exit (Out)!
(given by Right clicking on the empty screen of the Macro!!! )
And then Right Click on the News In & End for give the good nature (color) of Number, Point, Object
EDITED: 24 Jul 2020 by PILOU
9845.17 In reply to 9845.16
Thank you for your reply PILOU.
I downloaded the NodeEditor directly from [http://moi.maxsm.net/nodeeditor/].
Downdoaded an extensions.zip file which had in it the “curves2” and "SubDiv" and others.
Unzipped this file into [C:\...\AppData\Roaming\Moi\nodeeditor\nodes\extensions]
But I do not know how to access these functions (I am using moi V4beta)
9845.18 In reply to 9845.17
Hi redraw,
Did you setup the shortcut in the MoI shortcut keys menu?
I use F6 to start the node editor. There could also be a icon on the bottom menu to startup the node editor.
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
After it starts up, right click on the desktop to access the node menus. On the new version there is an icon in the left most corner with three horizontal lines that will display the node menus.
Wayne
9845.19 In reply to 9845.17
You must have something like this...(these windows are windows of my 2D prog drawing :)
9845.20 In reply to 9845.19
Thanks heaps guys
I will go over your posts tomorrow. My brain is jelly at this moment.
9845.21 In reply to 9845.19
Thank you PILOU,
I think all in now good.
Ready tio play.
Just One question
In the Helix, is it possible to have variable Pitch?
Or is this hard coded
I had a play with BASIC - RANDOM
and some other functions but the Pitch remains constant along the length of the Helix.
9845.22 In reply to 9845.21
Hi Maysky, re: .DS_Store - that's a file used on the Mac OS to store folder settings: https://en.wikipedia.org/wiki/.DS_Store .
You can just ignore it.
9845.23 In reply to 9845.22
Thank you Michael,
I just had a quick play with the Helix
A new question.
Is it possible to have a variable Pitch for the Helix
The length of the helix to increase as the helix plopogates?
Tried a Random Node but the whole lenght of the helix has the same pitch.
9845.24 In reply to 9845.23
I did a variable pitch script a few years ago.
It was not made into a node.
9845.25 In reply to 9845.24
Thank you Brian,
I will have a look.
Is there anything I should be aware of?
9845.26 In reply to 9845.25
Hi MAYSKY,
Link to the 3 versions that I did, 3 to 6 whole years ago. I have not reviewed the notes from back then,
but there is a difference between instantaneous initial and terminal pitch, and the pitches for the first and last turns.
https://moi3d.com/forum/index.php?webtag=MOI&msg=6697.11
Maybe I'll try to do a node. Due to being busy, no work has been done for the last 4 months :-(
EDITED: 24 Jul 2020 by BEMFARMER
9845.27 In reply to 9845.26
Thank you Brian,
I hava found and downloaded Two; “_VarPitchHelixExtremes” and “_VarPitchHelixVerbose”. Poking around I discovered what may be node! ... VarPitchHelix.nod it was by Barry-H in a post to you. (7777.374 In reply to 7777.373 ) form May2017.
I have not had a chance to play with anything yet.
I would truly love to be able to have a node or script that can construct a variable pitch helix that can follow a curved path as its main axis. Ideally the curved path is in the form a variable pitch helix. Like a macro in a macro or some such analogy.
Algorithmically speaking, do you think it’s possible?
9845.28 In reply to 9845.27
Hello Maysky,
here is an example how you can create such things without a special node. The point is that you can create special things by yourself;-)
Have a nice day
Karsten
9845.29 In reply to 9845.27
Kudos to Barry, Karsten, and Flow.
-♤♡◇♧ Brian
(Discovered extra symbols on Tablet)
Show messages:  1-9  10-29  30-39
