modelling question
All  1-10  11-19
Corchet recycled model ;)
9842.12 In reply to 9842.10
and a little render
EDITED: 26 Jun 2020 by FINEMA
9842.13
Wow - thank you so much for all replies! - I will work on this later today - now I have a new understanding…
9842.14 In reply to 9842.1
Hi Steve, also check out this previous thread for some good tips on how to apply some bending:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4471.1
9842.15 In reply to 9842.1
something more organic
1 draw a close curve ... apply Rebuild
2 extrude a little bit... delete the cap face ... select the border
3 apply a script named Blendcap
the max value seems to be 2.5 but you can exceed the number ( here i wrote 12 ) to obtain a rounder shape
if the border of the blend is splitted ( red line ) use the Blend command
blend is better in some case ( the cut line to split the border can be placed where you want to generate various shapes )
blend surface need to be closed by Planar command ... select the 2 faces join ... it's solid and can be " booleanized " ;)
la booléanisation du schmilblick ;)
EDITED: 9 Sep 2020 by CORCHET
9842.16 In reply to 9842.14
@Michael
...indeed... :) :)
M
9842.17 In reply to 9842.1
I modeled these sunglasses based on images from an eyeware store on the web.
The modeling concept is basically the same used by Mauro and Michael, except I didn't use Flow to curve the frame.
I wanted to keep the two stubs that support the hinges at 90 degrees to the frame as the drawing specified. Curving the entire frame would change that angle, although I could have made stubs separately and Boolean them in place after Flowing the frame.
The method I used was to make two cutting surfaces (curved in two directions) from Sweeps using curved Profiles: One with the nose rest profile for the back of the frame (orange), and one to cut the face of the frame (magenta). The orange surface was Extruded forward, then Boolean Diff with the magenta surface.
The temples (arms) were made in one go from a two-rail Sweep using three profiles. No Booleans, fillets, or flow.
I like doing these little modeling exercises as I learn something new every time :)
EDITED: 21 Jun 2020 by EDDYF
9842.18 In reply to 9842.17
@Ed
Cool glasses and material you applied to render
I readed my old post... after 10 years we are still here...Great!
9842.19 In reply to 9842.18
Mauro -
10 years ago I was learning how to sweep an oval around a circle to make a simple ring :) So I didn't give much attention to many of the postings of advanced techniques back then.
Now I search for topics and find some amazing information from the past! I started my own "Reference Book of Moi" in MS Word a few years ago by pasting text and images from various postings, sorted by subject.
Show messages: All  1-10  11-19
