Free Mini ZBrush!
 1-17  18-26
9839.18 In reply to 9839.11
if you manage to extrude each poly in pointy shape ... you'll be the creator of the hairy system in moi ;)
pareil j'avais essayé ... il met une plombe pour importer ;)
Pilou said " En tout cas fonctionne parfaitement comme prémodeleur organique pour Moi! :) "
i remember an old modeler with perfect quad topo on export ... Silo ! website : nevercenter
not very expansive 99 dollars
many tutorials ... easy to use
IMHO a great tool to add with easy import in nurbs software
9839.19 In reply to 9839.18
@ Corchet : or better this "free one" who has a direct Bridge in the 2 ways! ;)
https://rocket3f.com/ (English Page)
https://moiscript.weebly.com/rocket-3f.html (French Page)
Pont = Bridge to Moi
and Inside Moi a Bridge to Rocket 3F is added by a simple shortCut given at the Install of Rocket 3F
EDITED: 19 Jun 2020 by PILOU
9839.20 In reply to 9839.19
yes ! it's very nice too !!
Anything from Rocket 3F (here without suddive who is also possible of course :)
And of course will be better if you have "quadrangular" facetts ;)
Without subdiv inside Moi then One subdive inside Moi
After more subdive inside Moi or any Nurbs operation
Start from cubic forms inside Rocket 3F if you are not enought satisfied by the SubDive tools yet existing of MOi! ;)
(_SBridge, _sSplit, _Sscale, by Max SMirnov) + Extrude...
About SubDivide in nurbs :) https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
Here random selection inside Rocket 3F
EDITED: 20 Jun 2020 by PILOU
the 2 methods of direct importation from a Zbrush Mini file OBJ
Funny result with the _subdiv_beta9 of Max Smirnov !
More easy with the free MagicaVoxel : a simple Drag & Drop! :)
9839.25 In reply to 9839.23
"Funny result"
Looks like the faces weren't joined, so it subdivided each face individually...
Pretty cool look.
Pointillism
9839.26 In reply to 9839.25
Yes, it's just the option inside the SUbdivision when volume has not faces welded! (so separated)
Your can permit or not the SUbdivision...(preserve corners enabled or not)
Sorry the Plugin is in French even the UI is in English! :)
EDITED: 29 Jun 2021 by PILOU
Show messages:  1-17  18-26
