Double coil (helix spiral)
9836.1
Hello,
How can I make double coil by using moi3d.
Please see the attachment.
And Also
https://youtu.be/KPJKdabj4xA
Thank you
Size: 456 KB, Downloaded: 45 times, Dimensions: 1080x2023px
9836.2 In reply to 9836.1
Hi hunter07, you would make that by making 2 helixes using Draw curve > More > Helix, with a line running down the center axis of the thinner one like so:
Select the thinner one only (not the line though) like this:
Then run Transform > Deform > Flow, and select the line as the base curve and the squat helix as the target curve . That will produce this result:
Draw a circle a little ways away from it (outside the bounding box so that "auto place" mode for sweep will be used), and use Construct > Sweep to sweep it along the path to make a tube:
9836.3 In reply to 9836.2
Beautiful!
Thank you.
