Fillet lenght problems
All  1-6  7-11
9835.7 In reply to 9835.5
Hi Ray,
> OK, I understand your meaning but could this problem be fixed in the future or not.
> Thank you very much for your answer but I understand.
It could be possible to fix in the future but it's not an easy thing to fix, it will take quite a bit of work.
I think, it's a real unsolvable problem.
The nature of the face is to be a face with a surface and a perimeter.
Here, if you fillet with 2.5 the face is becoming null (a single point which is another nature of object), so it's like willing divide by 0.
the only possibilty to be near with filleting, I think, is cheating with 2.499.
You will have on UI a 2.5 written but in real a microface is done so you don't have a perfect dome like you want.
The problem, it seems, is you want a modification on the nature of the top face when the top is a single point.
So you can design it but you have to model it without fillet and model with a single top point, so the nature of the top is a point and not a face.
You can use :
- a rail revolve to do it with a square as rail curve with a master curve beginning from the "center top" you want.
- a network job with edges you want. Edges made with a master curve and a array/circular transform (to have your 4 edges of the dome)
- perhaps another exists...
If the program search during a filleting a aberration on a single point face to fix it, the problem is the same with a face becoming a single line (case of filleting rectangle 5x10) or a face becoming a curve on others cases.
Filleting is a very cool tool, but it has some limits.
If we want go beyond the limits, we have to search others solutions.
Have fun !
9835.9 In reply to 9835.8
you don't want of my little solution before an hypothetic native tool? :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9835.6
9835.10 In reply to 9835.9
s'il n'en veut pas ... c'est qu'il ne te mérite pas ! ;)
halte au fillet rond sinon ! ;) marre
fillet accidentel
fillet tour du truc en rail revolve
fillet blend sparadrap
fillet sur boule
fillet boite à pilules
fillet volants
fillet à facettes
et parce qu'on ne sait jamais ... le fillet parachute
hop
EDITED: 9 Sep 2020 by CORCHET
What a profusion of Fillets!
(@ Corchet : ne pas confondre avec un filet à provisions! :)
EDITED: 7 Jun 2020 by PILOU
Show messages: All  1-6  7-11
