Performance of vectorMath.createPoint
All  1  2-5
9831.2 In reply to 9831.1
Hi guschard, what version of MoI are you using?
9831.3 In reply to 9831.1
There is a big difference between v3 and v4 with this - for v3 the script is running in a separate process (moi_commandprocessor.exe) and there is interprocess communication overhead with every object access. However, this loose coupling allows for interrupting the script at any time.
It's different in MoI v4, in v4 the script is executed within the same main MoI.exe process and so there is a lot less overhead.
So if you were using v3 the first thing to try is to test it with v4.
9831.4 In reply to 9831.3
Hummmmmm, understood. I'm using V3, but I'll take a look at V4.
Thank you very much!!
9831.5
In the node editor: About 53ms to create 3000 points.
Added comments to the PointTest.js node file incase other users are interested in a simple node creation process.
- Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
Show messages: All  1  2-5
