can export shortcut
All  1  2-4
yes : find the file .../application data/moi/moi.ini
and you will have the new short cut key saved for another computer :)
but you must also copy past the new scripts or commands that you had used if you want that all work on another computer ;)
983.3 In reply to 983.2
ha ok ...
%APPDATA%\Moi\
thanks
Alari Vincenzo
http://xoomer.alice.it/gfx/
983.4 In reply to 983.3
Yup, you can just copy that file to your other computer to bring all your settings over.
You can either copy it to that same spot %APPDATA%\Moi\ , or you can also place the moi.ini file in the same directory as moi.exe, if it finds it there it will load it.
By default it puts it in that %APPDATA% dir because users who don't have admin rights can't write to files under \Program Files.
Show messages: All  1  2-4
