Sweep Mystery
All  1-2  3-8
9829.3 In reply to 9829.1
Hi Tom, try this attached version. This one has the sweep rail tuned up so that all segments are exactly tangent to each other.
Now it should not be trying to do any extensions and intersections for corner mitering.
Things that are really close to being tangent but just barely not tend to complicate intersections.
9829.4 In reply to 9829.2
Based on your explanation I found and fixed the issue. The solution will be invaluable to us!
I had widened the Sweep Rail by pivoting on a Corner Point. Based on your help, I pivoted on the standard point above it and it worked.
THANKS!
I love this product.
By the way, Version 4 is a bit more forgiving than Versions 3!
I will download your fix. Thanks, again.
EDITED: 27 Apr 2023 by TMEEKS
If it could help, to explore this mystery, when you move a point which is not a sweet point, the sweep is capped.
The path is made with hard and soft points with lines and curves joined.
If you use a rebuild fuction, the problem is resolved.
If you use a ReconstructCurve, it's solved too.
If you use the script delcorners, it's solved too.
Michael, is it possible to view the different types of points in MOI ?
Soft, Hard and those are semisoft/semihard ?
9829.6 In reply to 9829.5
"Michael, is it possible to view the different types of points in MOI ?
Soft, Hard and those are semisoft/semihard ?"
Great suggestion! I, too, would find this very helpful... as I did your accompanying suggestions. In fact, I will incorporate those ideas into our training to reduce the frustration of a sweep no acting as we expected.
Thank you so much!
For example, Inkscape do it with squares and diamonds
squares are soft points, diamonds are hard points.
Perhaps a script could change type of a point (or joint)
9829.8 In reply to 9829.5
Hi Phiro,
There isn't anything for that currently but it's something I would like to add in the future. It will probably be something that shows up in Join initially, like some kind of optional report after doing a Join that tells you if segment ends are tangent to each other or not.
Show messages: All  1-2  3-8
