Can you develop the selection function of painting circle
All  1-7  8-13
9828.8
When the point is selected inside the object, it is easy touch off the“move ”command. Can the move command be disabled? Turn on the move command after the selection.
9828.9 In reply to 9828.8
Hi FEIRUI445, if you hold down shift+ctrl, you can then drag a window selection without object dragging happening on the first click.
9828.10
Yes, I need it. Choose the inner point. Thank you!
In addition, sometimes the back control point is not needed. Is there any way to cancel it?
9828.11 In reply to 9828.10
Hi feirui445,
Not automatically but if you go to a different view you can then do a Ctrl+drag window to do a deselection window instead of a selection window.
9828.12 In reply to 9828.11
Thank you, very convenient
9828.13
Hi feirui445,
Marco was working on a lasso select add-on a few years ago.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8830.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.33
Wayne
Show messages: All  1-7  8-13
