rotate / translate faces
All  1-3  4-17
9824.4
thanks for the replies guys
pilou. sorry man. is this a plug_in that might have the rotate face functionality ( like fusion ) ?
9824.5 In reply to 9824.4
MoI is not a parametric tool, just a superb application for designer and concepters :)
9824.6 In reply to 9824.4
You mean Rotation the Fillet like Minute 16.30 ?
9824.7 In reply to 9824.6
yeah that's one example of the functionality at work. real powerful stuff
9824.8 In reply to 9824.7
I haven't thought about this particular rotation of Fillet but if you can draw the result with Moi
I believe that you can do it also with Elephant! ;)
Will be maybe not exactly the same animation than Fusion but the result will be the same! ;)
Here an horizontal rotation not yet that you want but just for show Elephant possibilities! ;)
Of course Start End Fillets can be variable if needing... not made completly here :)
And the mystery quasi revealed! :) Hyper simplex : the Pivot point is not yet moving itself!
What a design editor! Thx to Max Smirnov for make such prodigies! Funny challenge...
EDITED: 28 May 2020 by PILOU
9824.9 In reply to 9824.8
now THAT is some magic
with what fusion is doing. it's not restricted to chamfers as such. just any valid face selection can be rotated. and you can set the pivot point etc
9824.10 In reply to 9824.9
Yes of course ;) It's named "total direct modeling"
Moi is "partial direct modeling" in evolution! ;)
9824.12
c'est sympa fusion 360 ... ça sert de tuto pour Moi ou Rhino+Tsplines ... quand on a que ça à regarder ;)
sinon la coupe paramétrique ... que l'on voit sur la vidéeo ... c'est un peu comme ne pas trop savoir à quel endroit on veut couper le bazar ... koi
et puis la souscription à 480 euros par an ... ça fait cher pour au final ne faire que du kitbash déjà vu 1000 fois ailleurs
eh non ... je ne me suis pas levé du pied gauche !!! ;)
9824.13 In reply to 9824.12
@Corchet
Oui mais non! On peut utiliser Fusion 360 de façon gratuite! ;)
Je l'utilise ainsi depuis des lustres! :)
Prendre la "Personnal"...dans le temps c'était pour "enthusiast" !
et on la renouvelle tous les ans! Pas une grosse difficulté! ;)
Une des moins compliquée des usines à gaz! :)
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-activate-start-up-or-educational-licensing-for-Fusion-360.html
C'est quand même une solution complète! Et pour le prix et le fun, c'est amplement suffisant! :)
Some years ago ...
EDITED: 30 May 2020 by PILOU
9824.14 In reply to 9824.13
oui mais non ... j'étais en mode taquin ;)
j'ai supprimé à l'époque où il plantait à tout va
certaines vidéos sont intéressantes histoire de voir ce qu'en font les gens ... la partie subdiv surtout
non je réagissais au prix exorbitant ... ces souscriptions abusées
et puis il faut soutenir les " petits producteurs " quoi ;) ... 3dcoat ... tt ça ;)
9824.15 In reply to 9824.14
@Corchet
Ah le mode taquin ...attention...il manque toujours une case ! :)
Bonne chance! :oD
Il y a OnShape online aussi...mais pas sûr qu'il soit resté gratoche...en fait si...encore un monstre...
https://www.onshape.com/products/free
Ah oui, 3D Coat :) Je crois que c'est moi qui avais fait la version française du programme, du site (je continue d'ailleurs) ... :)
Mais maintenant chacun peut faire sa propre version de langue de l'UI...l'est très fort l'Andrew!
https://3dcoat.com/fr/
Un mixte gratuit sympa ! Rocket 3F, TwinMotion 2019-2020 pour le rendu, l'animation d'ambiance...
(fallait bien sûr avoir chargé la 2019 quand je l'avais conseillé! )
https://moiscript.weebly.com/rocket-3f.html
https://moiscript.weebly.com/twinmotion.html
EDITED: 31 May 2020 by PILOU
9824.16 In reply to 9824.15
" Je crois que c'est moi qui avais fait la version française du programme, du site (je continue d'ailleurs) . "
alors c'est le moment idéal pour te remercier !! pour ça et tt le reste !! ;) ... sincérement
et si je ne peux emporter qu'un seul programme sur une ile deserte ... c'est 3d coat sans l'ombre d'une hesitation !!!
9824.17 In reply to 9824.16
...et Moi pour le fun! ;)
Show messages: All  1-3  4-17
