Custom UI Question [View Buttons]
All  1-4  5-7
9821.5 In reply to 9821.4
Thank you very much for your time and for so kindly helping me. I do always appreciate your effort and support.
That's great! I must admit that the non-reverse functionality is a bit of a game changer, as I use the reverse function quite a bit. However, it's very interesting to learn the difference between the ViewTabs.htm with the images and with the text. I'm really interested by the htm|css coding and would like to learn a little more, as I can see that it would benefit the understanding of MoI's backend greatly. It's really a balancing act between using the software creatively and tinkering with its functionality and appearance. Either way, it's great fun!
Really encouraging to hear of the next v4 beta and thank you for being so open and engaging with your users.
Kindest regards,
Tim
9821.6 In reply to 9821.4
Actually, I've just thought of something else relating to the view buttons that I had meant to ask you...
Assuming that I am using MoI without the custom icons (with the text labels), I was wondering if there is a way of left-clicking on the view button to reverse toggle instead of the right-click? So for example, when left-clicking on Top, it toggles to Bottom and vice versa.
Thanks Michael.
9821.7 In reply to 9821.6
Hi Tim,
That's actually how it works currently. If the Top view is the active tab, then when you left click on it , it toggles to Bottom.
If the one you left click on is not active, it will become active. If you then left click it again while it is active it will toggle.
Show messages: All  1-4  5-7
