Ship hull tutorials
 1-16  …  37-56  57-76  77-96  97-116  117-129
9819.77 In reply to 9819.74
Yep this serial of videos is very instructive how is made a wood boat! !
(i am on 20/73...; )
And Albert Strange a cool artist and Yacht designer!
https://en.wikipedia.org/wiki/Albert_Strange
Hull Plan of Tally Ho from another cool site : https://davestallyhomodel.blogspot.com/2019/02/the-first-steps.html
Amazing stuff!
EDITED: 9 Jun 2020 by PILOU
9819.78 In reply to 9819.76
Thanks. Yes, it was network surface then boolean joined. It's not repairable then? I know I'm doing a difficult shame again as one part has to go down to basically nothing, whilst the other upper part has to be 90 deg. to it. Not sure what to do now. It is OK on loft, but it doesn't follow the plan shape too accurately though.
EDITED: 26 Jun 2020 by NEOMEGA
Size: 1.3 MB, Downloaded: 27 times, Dimensions: 1788x996px
9819.79 In reply to 9819.78
Maybe you can see the videos about hulls about this site (and free prog ;)
(not so easy than moi! ;)
http://www.polycad.co.uk
9819.80 In reply to 9819.78
Hi Gord,
It looks like there are just a couple of spots where the endpoints don't touch. It would probably be a good idea after you construct one of these networks that you want to join to other straight parts, to edit surface control points and ensure the end control points are all trued up to be flat so the ends will be planar.
It's probably things waving around just a little bit out of being planar that is causing enough misalignment to be problematic.
It might be, I'll take a crack at it.
9819.81 In reply to 9819.80
Appreciate it, thanks!
Is there a scrip I can run to allow me to see these problem areas highlighted larger? I use N, but it only shows the whole edge.
G
9819.82 In reply to 9819.81
Hi Gord, there isn't any script for that, you just zoom in closely especially on corner areas where things join up. You can use the "Zoom area" tool to zoom in centered on a specific spot.
9819.83 In reply to 9819.81
Hi Gord, here is a stern piece which should be all trued up. I think this could use it here too though:
9819.84 In reply to 9819.81
Hi Gord, I guess I planarized a little bit too much, I guess I should not have pulled this one up to be planar:
I was kind of thinking the upper surface wanted to be a simple straight extrusion.
9819.85
Hi Gord,
Your constant issues with lines not meeting or touching makes me wonder whether you have "Object Snap" switched "ON"..?
If not, then may be that could help to explain a lot of your issues?
HTH, Colin
9819.86 In reply to 9819.85
Hi.
Thanks, I thought I did do - see the screenshot. Must I alter numbers somewhere?
Gord
Size: 448.6 KB, Downloaded: 33 times, Dimensions: 1396x1086px
9819.87 In reply to 9819.86
Funny! Never used even don't remember that is existing! :)
Maybe because i don't use millimeter as unities
Seems all is enabled!
9819.88 In reply to 9819.86
gaps and a huge amount of points on curves ... don' t forget to rebuild
the central part have issues ... lonely faces .... better to contruct this as an extrusion + boolean hole
and 2 half hulls ... union give the baby solid
i add a round piece ... à l'avant qui fend les flots ;) ( 3dm joined )
ps i can't reproduce the exact shape of your hull ... cause you post the result of the network and not the curves needed to built it ;)
EDITED: 9 Sep 2020 by CORCHET
9819.89 In reply to 9819.83
That's awesome Michael! I have now added the raised plate that covers the join as it looks like it grew there! Many thanks!
G
9819.90 In reply to 9819.89
Hi Gord, so is that going to work ok for you? Are there other problems to fix still?
So I think one problematic thing in your original one is the alignment between these pieces here:
The one on the left looks like it's trimmed off from a horizontal line:
Then the one on the right is the natural end of a Network surface:
The problem is that even if this edge:
And this edge:
Are both on the same plane that isn't going to be enough for them to get glued together well. The edge on the left coming from a trim that is interior to the surface while the one on the right coming from a curve used in Network is not going to guarantee that the shapes are going to be close enough together.
It's good for these juncture areas to be formed either by being constructed off of the same end curves, or by being intersected with each other. One coming from a trim and the other from a separate curve is not going to be good.
So if you then build separate block chunks out of these things and then try to boolean them together it's going to be something similar to this (shown exaggerated here):
And if they are pretty close to the same shape but not close enough to actually merge together, those little "shelf" pieces above are going to be really skinny slivery things which you don't want to have.
That's one of the ways things can actually get worse when things are really pretty close to matching up but just not quite enough.
The other possibility to get things like this glued together that are not quite aligned is instead of making 2 blocks right up next to each other you could leave some empty space between them and put in a transition surface like a Loft or blend between them.
9819.91 In reply to 9819.90
That looks good now! I need to find how to get surface aligned manually. So you can't join solids and surfaces, but I still don't know why it gets out of square after I draw it on perp. lines.
Thanks, I'm sure I'll come across some other issues when my skills run out again!
G
9819.92 In reply to 9819.90
If I wanted to add a plate effect, where the thing is covered with plates but some standing slightly proud. How could that be done?
G
9819.93 In reply to 9819.92
Depending if you really want the physical material effect or just at the rendering ?
Only material
or simulated by textures
EDITED: 10 Jun 2020 by PILOU
9819.94 In reply to 9819.92
Hi Gord,
Do you maybe have an image showing something similar to give a better idea of what you want?
9819.95 In reply to 9819.94
This sort of thing?
EDITED: 11 Jun 2020 by NEOMEGA
Size: 1.9 MB, Downloaded: 37 times, Dimensions: 1862x1106px
9819.96 In reply to 9819.95
Hi Gord, something like that would usually be applied as some kind of texture map in a rendering program rather than directly modeled.
What are you planning on doing with this model, did you say something about 3D printing it?
Show messages:  1-16  17-36  37-56  57-76  77-96  97-116  117-129
