Ship hull tutorials
 1  2-21  22-41  42-61  62-81  …  122-129
9819.22 In reply to 9819.17
Rebuilt it all now, but used fewer waterlines.
Now I want it as a solid, but the shell offset won't have any of it.
Gord
EDITED: 11 Jun 2020 by NEOMEGA
As the hull is difficult to close...
Just a little trick... ;)
More the hull and the line will be near better will be the result wanted... :)
That want not to say that the Hull is good but it's a solid! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/brede3.3dm
ps Not "Trim" but Boolean Diff of course else hull will be not closed! ;)
EDITED: 31 May 2020 by PILOU
9819.24 In reply to 9819.23
Hi.
Not sure I understand what is happening here.
G
9819.25 In reply to 9819.24
About what ? If you have any question about the process don't hesitate!
It's very hard to correct a hull who has some defaults inside except all redraw...;)
So anyway for give an idea of the volume if you want make a 3D Print for any reasons
you can with your yet made hull make this trick above...
There will only few millimeters height difference between result and optimum wished! (1 or 2 mm)
As now it's a solid you can make any boolean operations you want for simulate the Shell
so
With the super cool free and easy one Simlab Composer Lite! (max 1920 *1080 )
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
9819.27 In reply to 9819.22
Hi Gord,
It's the same thing I wrote above (http://moi3d.com/forum/index.php?webtag=MOI&msg=9819.15):
quote:
Hi Gord, the shell command can only really handle thickening an open surface into a solid if it has all smooth pieces. When there are sharp edges like you have here the surface offsets do not touch each other and would need to be extended and intersected with each other and MoI's shell function is not good at doing that.
Additionally if you have any really tight bends or bumps in it that will be difficult for it to generate an offset surface from as well. An offset surface is generated by moving a distance away from the surface along its surface normal. If the surface normal is wiggling around chaotically it will become magnified in the offset and mess it up.
And also
quote:
3 sided networks can be problematic because the surface generated from it will have one of its sides collapsed down to a point and it is pretty easy for something with bends in it to then have really small tight bends in the collapsed down spot. Instead of a 3 sided network it is usually better to form areas like that by having a larger extended 4 sided surface that then becomes 3 sided by it being trimmed rather than trying to directly construct a surface to those curves. Then a fillet or blend can connect it to the other part.
The 3 sided network on the back has a chaotic wiggly mess at the collapsed tip area here:
The 3 sided network on the front has a chaotic wiggly mess at it's collapsed area too:
If you zoom in very closely to the tip area you can see that it has a lot of bumps and folds in it in a very small area:
Bumps and folds like that means the surface normal is changing wildly in a very small area, that will make the surface offset go crazy there as it tries to build something along the normal. The offset is kind of like taking a stick and sliding it along the surface, any wobbles or folds in the surface get magnified on the offset. So there isn't going to be any chance to get a good surface offset on stuff like that. In general I'd recommend avoiding making 3 sided network, you need to do things like make an extended 4 sided surface and then trim off some area like I wrote about previously here:
Your middle 2 pieces are ok, you can separate those out into 2 individual surfaces and use offset on those to get the thickening process going like I described above here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9819.16
9819.28 In reply to 9819.25
Please explain what you did to make it all solid?
I have redone everything, so this is the hull before the decks are cut down.
9819.29 In reply to 9819.28
Pefect just make the same that on my image above!
Create a solid box
Put the boat just a little inside
Boolean Union : you have a solid!
Draw a line any where you want but just under the box
Boolean Diff = you have your Hull solid
And you can now make a Boolean diff between your new hull
and the same hull some scaled
as shown on previous post
And after you can add 1 mm or more if you want! ;)
Move the face for make the little Shell
But all that because your curves were not perfect from the beginning...
A little shell
EDITED: 1 Jun 2020 by PILOU
Else with your last file!
You can Loft each side one by one
At the bottom deck joint the 2 curves before the last Loft
Delete all curves
Join All surfaces
You obtain a solid! ;)
That don't want say that your deck is a pefect plane and your curves perfect curves! ;)
But you have a perfect solid! ;)
9819.31 In reply to 9819.28
Hi Gord,
Unfortunately it seems like a step backwards in surface quality. You've now got a lot of separate surface strips that are not smooth to each other:
That's going to make it more difficult to generate offset surfaces to thicken it. You could try thickening it by directly modeling an inner wall instead of using Offset to make it like you could use if the surface quality was better.
The back end still suffers from 3 sided areas that are collapsing to a point while simultaneously trying to go a transition area.
As described above, usually these kinds of transitions are better to do as a separate surface using fillet or blend, rather than trying to construct a surface that tries to negotiate that type of shape change directly.
The triangular collapsed down to a point area here is not quite as chaotic and messy as previous versions, but it will still have problems trying to generate an offset surface from it. Offset surfaces have some general difficulty dealing with pole points where a surface edge collapses down to a single point. That's why I've been recommending over and over again not to try and model the back part this way.
If i can give you a little advice :)
Make some training with the method of the Post N°10
https://moi3d.com/forum/index.php?webtag=MOI&msg=9819.10
Like this you will have the good curves, learn to draw curves with the minimum of control Point
(better if you have same number of them by section)
And after you will create your own!
Bon courage!
9819.33 In reply to 9819.31
OK, I understand about doing the stern differently. But how can I get a smooth surface rather than separate strips now? I've realised how to make it all a solid though, so at least some progress is made somewhere!
I realise I'm trying to do something too hard for my meagre skill level though!
G
9819.34 In reply to 9819.33
Hi Gord,
2 things - you need to have smooth curves and you also need to build it as a larger piece instead of just one sub-section at a time.
See here for some description of why:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
Are the curves that were used to construct that in the file? It seems like there are a couple different sets in there.
9819.35 In reply to 9819.33
Hi Gord, and yes this is a pretty difficult area of modeling, no doubt!
9819.36 In reply to 9819.34
Thanks!
I think I need the waterline sections, at least one, to smooth it out. The plan I have to use does not have all the hull lines drawn. I realised a way to do this now.
G
Ok found an image of what i said previously! ;)
You understand with this system that you can't have sharp form! ;)
All is natural smooth line!
EDITED: 2 Jun 2020 by PILOU
9819.38
pict 1 : to be clear ... a boat with few lines ... and 4 networks to do the external hull
the 2 construction lines at the back can be easily modified ( edit point etc ... )
pict 2 : in yellow .... i copy the lines and do a small scale ( scale 3d - boundary box - type .98 ) 98 percents
i need to align the group of yellow lines on the x axe ( in right view ) so later the bastingage will be horizontal
pict 3 : now i have an external and an internal hull - they need to be joined
pict 4 : the most important !! i draw 4 segments to join the hulls ( i zoom very close for each segment ) to prevent gaps
i select the border of each network patch and do JOIN to be sure to obtain a closed curved ( without that ... no solid later )
when i see Closed curved , i can click separate
pict 5 : the 2 hulls are joined correctly ... select all the faces and join ... now it's a solid wich can support holes and various details
EDITED: 9 Sep 2020 by CORCHET
9819.39 In reply to 9819.38
3dm here
9819.40 In reply to 9819.39
peut etre mieux quand c'est moins pointu-tutu ;)
9819.41 In reply to 9819.40
some polygonal modelers like 3dsmax have a shell modifier ( with precision & efficiancy )
you can export a nurbs model with impossible shell ( thru OBJ ) and import for example in max ( c4d or blender ?? ... don't know them )
Max will show you holes on the surface of the shell if the nurbs model has not perfectly joined surfaces
if the shell is correct ... reimport in the nurbs software et voilĂ
Show messages:  1  2-21  22-41  42-61  62-81  82-101  …  122-129
