Ship hull tutorials
 1-2  …  83-102  103-122  123-129
9819.123 In reply to 9819.119
That's basically a problem area to work with since these original hull surfaces didn't align very precisely here like I was talking about earlier above:
This area at the top of that juncture now has problems with edges not meeting up with each other very closely and that kind of loose tolerances will tend to increase "glomming together" in intersections through those spots.
If you're going to be doing more stuff along those joining areas then it's good to get them aligned cleanly from earlier on, it helps to avoid problems further down the road.
9819.124 In reply to 9819.123
OK, thanks. I moved it away from the little parts as it worked. However, on another part, when I boolean, it suddenly deletes the structure for some reason! What happened?
I slowly learn!
G
9819.125 In reply to 9819.124
Hi Gord,
If you post the model I can take a look. It's hard to guess what might be going on without the model.
But it's probably related to those problem spots with micro faces and edges that don't connect to each other very accurately like I was talking about above.
9819.126 In reply to 9819.125
Could be that, if that happens. I've redesigned that bit now and put the rails on if a slightly different place. All a solid!
G
Minutes 14.00 and following..
Minutes 2.30 and following
Minutes 7 and following
EDITED: 13 Jun 2020 by PILOU
Polycad if free! ;)
http://www.polycad.co.uk/ Import Export IGES so entierely Moi3D compatible! ;)
https://moiscript.weebly.com/polycad.html French version of the site ;)
Just a part of an huge prog!
They are progressing!
Show messages:  1-2  …  63-82  83-102  103-122  123-129
