Ship hull tutorials
 1-19  …  80-99  100-119  120-129
9819.120 In reply to 9819.118
the "Lofter" as i said in my previous post! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9819.109
9819.121 In reply to 9819.119
Don't hesitate to "inflate" your object before the Booleans operations!
9819.122 In reply to 9819.119
Hi Gord,
> Sometimes though, swept rails just won't boolean into another solid surface, whereas others had
> no problem. See the two rails on his one.
Similar to how it is difficult to intersect a surface that skims right along another surface area it can also be difficult to have skimming edges like you've got here:
Another problem is in this area where you're trying to boolean there are some microstructures:
It will probably be difficult to do a boolean cut that has to try and intersect through that messy area.
> And why, when you boolean does the object sometimes disappear?
Part of the sequence of doing a boolean is it intersects the 2 objects and then needs to gather well formed closed intersection curve results which it then uses to partition objects into different pieces. If it was not able to get a good closed intersection then it can get confused about how to divide pieces up. The pieces that disappear were being classified as being in the volume that is to be discarded. If there are a lot of little tiny fragments in the area that is being intersected they can get partially glommed together and that can impede getting a well formed close intersection.
So it's not good to do repeated booleans of pieces that are kind of close to being aligned but just a little bit off, that can make those little slivery pieces.
9819.123 In reply to 9819.119
That's basically a problem area to work with since these original hull surfaces didn't align very precisely here like I was talking about earlier above:
This area at the top of that juncture now has problems with edges not meeting up with each other very closely and that kind of loose tolerances will tend to increase "glomming together" in intersections through those spots.
If you're going to be doing more stuff along those joining areas then it's good to get them aligned cleanly from earlier on, it helps to avoid problems further down the road.
9819.124 In reply to 9819.123
OK, thanks. I moved it away from the little parts as it worked. However, on another part, when I boolean, it suddenly deletes the structure for some reason! What happened?
I slowly learn!
G
9819.125 In reply to 9819.124
Hi Gord,
If you post the model I can take a look. It's hard to guess what might be going on without the model.
But it's probably related to those problem spots with micro faces and edges that don't connect to each other very accurately like I was talking about above.
9819.126 In reply to 9819.125
Could be that, if that happens. I've redesigned that bit now and put the rails on if a slightly different place. All a solid!
G
Minutes 14.00 and following..
Minutes 2.30 and following
Minutes 7 and following
EDITED: 13 Jun 2020 by PILOU
Polycad if free! ;)
http://www.polycad.co.uk/ Import Export IGES so entierely Moi3D compatible! ;)
https://moiscript.weebly.com/polycad.html French version of the site ;)
Just a part of an huge prog!
They are progressing!
Show messages:  1-19  …  60-79  80-99  100-119  120-129
