Batch filleting
 1-18  19-22
9808.19
as always lightning service many thanks Michael Ill have a play.
regards
Alex.
You can also use something like that! ;)
(some more versatile: works with any forms and without edit any codes :)
BoundingBoxCenterMultiple by Michael Gibson https://moiscript.weebly.com/uploads/3/9/3/8/3938813/boundingboxcentermultiple.zip
Can be used to simulate a replacement of objects
By coupling it for example with CopyToPoints or Vclone from MaxSMirnov
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
https://moiscript.weebly.com/burman.html (all scripts and commands collected by Burman)
Vclone replaces the vector by the object with size and orientation of the vector!!!
Following with BoundingBoxCenterMultiple & CopyToPoints
Of course a Circle can be used against here a Cylinder! ;)
EDITED: 13 Feb 2023 by PILOU
9808.21 In reply to 9808.15
Hi Michael
batcheditcircles脚本在V3中,无论是否选中圆,一直显示该错误。(The batcheditcircles script in V3 consistently displays this error regardless of whether a circle is selected or not.)
能否通过修改使该脚本能在V3中,能够正常使用?(Can the script be modified to work properly in V3?)
9808.22 In reply to 9808.21
Hi SUIYAN,
The script needs curve properties .isCircle and .conicRadius which were added in V4.
So it requires at least MOI version 4 to run, it would be difficult to make it work in V3, sorry.
Show messages:  1-18  19-22
