match surface??
9799.1
Hey all,
In Rhino the is a Match Surface tool. This lets you match continuity between two surfaces. Is this possible in Moi?
Attached shows front view of surface #1. When I mirror it over to surface #2 the two surfaces do not have continuity.
Alan
EDITED: 9 May 2020 by ALANO
Size: 38.4 KB, Downloaded: 36 times, Dimensions: 846x710px
9799.2 In reply to 9799.1
Hi Alan, sorry no MoI does not currently have a match surface tool like that. If you need that right now it would be good to use Rhino in combination with MoI and do that particular task in Rhino.
But if you are constructing surface 1 out of some curves usually it is best to construct a single larger surface instead of half and then there is no need for any additional matching.
See here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
9799.3 In reply to 9799.1
As a remedy you can cut the center portion out from both surfaces and use Blend....
9799.4 In reply to 9799.3
Thanks Michael and Burrman.
-Alan
