Extrusion
All  1-10  11-12
9785.11 In reply to 9785.9
It's only the ones on the top that are fragmented like that, the ones on the bottom seem ok.
I've attached a reconstructed version made by extruding the bottom curves, I think it should behave better now.
Do you remember what process you used to build this object? It could be good if I can figure out why the top edges were broken up into so many different edges. Maybe I can fix whatever made it get fragmented.
9785.12 In reply to 9785.9
Show points ... give a strange result on your construction circles
better result if you apply Rebuild on your draw elements
and the parasite vertical line disappear
now you can extrude the upper disk
EDITED: 9 Sep 2020 by CORCHET
Show messages: All  1-10  11-12
