Car made in Moi.
All  1-3  4-7
I am waiting the Moi tuto of this car made principally with "NetWork" !
9782.5 In reply to 9782.3
Hi Oskar, it looks great! So probably with a complex shape like that to hollow it out you would need to model the inner surfaces manually, with less detail. Some pieces can probably be created by using Offset on some individual surfaces.
9782.6 In reply to 9782.1
That's a really nice render OSKAR! A nicely modeled VW T3 too! Well done.
If it helps a little with the UV mapping, a really useful technique that I have learnt is to assign colour styles to the surfaces that you want to add textures or stickers to. By adding a colour style to the surfaces where you want a texture, MoI will actually assign a Polygon Selection tag to the area where the colour is. What is great about this, is that it makes it very easy to select and UV unwrap those parts of the model that have the colours assigned. If you had the time and the patience, you could actually assign a different colour to all of the parts and have Polygon Selection tags assigned to the whole thing, any part that has a different colour would be a separate UV island, making texturing much easier.
I hope this helps?
Kind regards,
Tim
9782.7 In reply to 9782.3
""""""inner shell, Guess you cant flip the normals? """"""
If you select your surface, hit tab and type flip, your surface direction will change.
Show messages: All  1-3  4-7
