Line order and direction
1-19
20-22
Michael Gibson
16 Sep 2020 (20 of 22)
9781.20
In reply to
9781.16
Hi Wayne, another way you can determine the direction just using 2D points is to make a 2D triangle and then compute the signed area of the triangle:
https://www.quora.com/What-is-the-signed-Area-of-the-triangle?share=1
It will be a positive number for CCW, and a negative number for CW.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
wayne hill (WAYNEHILL5202)
17 Sep 2020 (21 of 22)
9781.21
In reply to
9781.19
Yes, I am only using the top view plane. The methods you suggested will be looked at in closer detail.
Thank you.
Wayne
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
pressure (PEER)
12 Sep (22 of 22)
9781.22
Here's a small update to the orderCurves plugin that works on curves smaller than 1 unit long.
orderCurves.zip
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
20-22
