import OBJ
All  1-2  3-13
9780.3 In reply to 9780.1
Hi Wim, the new OBJ importer in v4 is not a general purpose importer that can read in any type of OBJ file, it is for converting OBJ files that are set up for sub-d smoothing.
So if you have a sub-d model you can use that to convert it to a smooth NURBS surface model in MoI.
If your OBJ file just contains regular polygon mesh objects and not ones set up for sub-d smoothing, that type of data is not good to import into MoI.
> where can I find a tut or user manual for V4?
There isn't one yet, I'll be working on that once the last beta is finished.
9780.4
Ok Tnx Michael, my intention was to import a specific custom sized bolt thread which I have as stl only, and redraw it in MoI. but as I understand it (and just tested a few minutes ago) the original shape is lost and turned into subd smoothed geometry.
So I will have to screen dump it in Blender and import the image I guess.
wim
9780.5 In reply to 9780.4
You have also an STL importer so you must not loose the original shape... ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9546.9
9780.6 In reply to 9780.5
tnx Pilou, I will try that one!
wim
9780.7 In reply to 9780.6
Not sure STL that will be paradisiac ;)
If i remember! :)
http://moiscript.weebly.com/r2d3.html
but try also the _importBj by Max Smirnov
maybe that can works no so bad for your piece!
http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
9780.8 In reply to 9780.7
tried them both but gave same result...
our should I try this in 3.2?
9780.9
the obj import to subd:
Size: 149 KB, Downloaded: 102 times, Dimensions: 529x759px
9780.10 In reply to 9780.9
Yes try in the V3 because it's an old one ;)
About the obj with _importObj what is the result?
http://moiscript.weebly.com/_importobj.html
EDITED: 26 Apr 2020 by PILOU
9780.11 In reply to 9780.10
wow, that one totally works! (I overlooked it in the comment above, my bad...
thanks Pilou!
w
9780.12 In reply to 9780.11
Yep so seems maybe you will have a better result in "Quadriangulate" with some third party first before importation! ;)
Maybe this free one! ;)
https://github.com/wjakob/instant-meshes
9780.13 In reply to 9780.11
The STL import one only supports ascii type STL files, not binary ones.
Show messages: All  1-2  3-13
