Easy way to select Fillet Faces?
All  1-8  9-17
9775.9 In reply to 9775.8
Michael -
Changing my moi.ini to: DisableSubObjectStyles=n fixed the issue. That's weird because I've rarely changed settings, and only when a forum posting gives a good reason to (I don't know what most those settings do anyway :)
I tested the scripts on some complex geometry and it works very well. Beats clicking on all the individual fillet faces to assign a style. Hopefully you can get it down to one script on future versions.
Thanks again for the great support!
9775.10 In reply to 9775.9
You're welcome Ed, I'm glad it's working now!
For the next v4 beta I've added in a .isNew property on faces that will tell if it is a newly created one. That will remove the need for the pre-fillet script.
As I have made it for my French site!
Not a big deal to convert :)
9775.12 In reply to 9775.2
Instead this may be add some code to moi.geometryDatabase.selectLastCreated() for new created fillet support?
9775.13 In reply to 9775.12
Hi Quaritexa,
I have added a new moi.geometryDatabase.getLastCreated() as a helper to use for this.
There is also a similar flag added on edges so new edges that were created by the intersection between objects instead of as a copy or trimmed part of an existing one can be targeted as well.
9775.14 In reply to 9775.13
Will there be documentation on api v4?
9775.15 In reply to 9775.14
Hi Quaritexa,
I can put together a list of new properties and functions that are available since they are not derived from moi.idl anymore.
9775.16 In reply to 9775.15
With short descriptions?
9775.17 In reply to 9775.16
Probably the same ones from the beta release notes.
Show messages: All  1-8  9-17
