Easy way to select Fillet Faces?
All  1-3  4-17
9775.4 In reply to 9775.3
Hi Ed, I can't repeat that problem over here. Here's what I tried:
Made a box and selected this edge to fillet:
Ran pre-fillet script, did fillet, then ran post fillet script:
Assigned style to the fillet, then selected other edge:
Assigned style to new fillet:
Are your steps different?
That's interesting. I'm on Ver 4 Jan 22,2020. Assigned Mark Script to ctrl-F and the After Fillet Script to ctrl-G.
Using the same steps on a box as you outlined. I hit ctrl-F after selecting the edge, then I Fillet. After I hit "Done" I ctrl-G, the fillet highlights, and I assign a new color.
The newly assigned Fillet color disappears as soon as a 2nd Fillet is applied to the box (whether or not the scrips are run for the 2nd Fillet). I also tried assigning the color before and after hitting "Done" on the fillet operation - same results.
Maybe another user can test this and comment.
Ed
9775.6 In reply to 9775.5
Hi Ed, hmm yes I'm using the same version. What method are you using for assigning the color?
9775.7 In reply to 9775.6
When the 2nd script highlights the fillet face I click once on one of the colors in the Styles pane.
I can then go do another task, like draw a circle, and the new color remains on the box fillet face.
But if I come back and do any type of operation on the box, such as extruding a face, the newly assigned color reverts back.
- Ed
9775.8 In reply to 9775.7
Hi Ed, and if you don't use the script at all and just select the face by a click that doesn't happen?
In your moi.ini file do you possibly have:
[Styles]
DisableSubObjectStyles=y
9775.9 In reply to 9775.8
Michael -
Changing my moi.ini to: DisableSubObjectStyles=n fixed the issue. That's weird because I've rarely changed settings, and only when a forum posting gives a good reason to (I don't know what most those settings do anyway :)
I tested the scripts on some complex geometry and it works very well. Beats clicking on all the individual fillet faces to assign a style. Hopefully you can get it down to one script on future versions.
Thanks again for the great support!
9775.10 In reply to 9775.9
You're welcome Ed, I'm glad it's working now!
For the next v4 beta I've added in a .isNew property on faces that will tell if it is a newly created one. That will remove the need for the pre-fillet script.
As I have made it for my French site!
Not a big deal to convert :)
9775.12 In reply to 9775.2
Instead this may be add some code to moi.geometryDatabase.selectLastCreated() for new created fillet support?
9775.13 In reply to 9775.12
Hi Quaritexa,
I have added a new moi.geometryDatabase.getLastCreated() as a helper to use for this.
There is also a similar flag added on edges so new edges that were created by the intersection between objects instead of as a copy or trimmed part of an existing one can be targeted as well.
9775.14 In reply to 9775.13
Will there be documentation on api v4?
9775.15 In reply to 9775.14
Hi Quaritexa,
I can put together a list of new properties and functions that are available since they are not derived from moi.idl anymore.
9775.16 In reply to 9775.15
With short descriptions?
9775.17 In reply to 9775.16
Probably the same ones from the beta release notes.
Show messages: All  1-3  4-17
